Horrible Creakings/Squeaking From Rear
Old Jun 26, 2012 | 07:25 PM
daniel3ooo's Avatar
Hey fellas,
When I originally purchased my car there was a slight creaking/squeaking sound coming from the rear. It mainly occured when I was making a U turn or reversing up a ramp.
I recently lowered my car on KW V1's and the creaking sound has gotten significantly louder. It now happens on not only U turns and reversing, but also going over uneven pavements.
I took my car to my local shop and they greased the bushings at the end of the rear sway bar but that didnt help. We looked under the car and came to the conclusion that it could be the rear end links. When he pulls on the sway bar you can hear the creaking coming from that area.
My question is could it be something other than the rear end links? I plan on purchasing the AMS rear end links to try and eliminate this problem but wanted to know if anyone else had any other suggestions. I did do a search but it doesnt seem like many people have a creaking sound from the end links.
Any ideas? Thanks in advance!
Old Jun 27, 2012 | 01:26 AM
daniel3ooo's Avatar
Just ordered some OEM endlinks on ebay for about $30..will try to see if that eliminates the noise..if anyone has any other ideas please chime in!
Old Jun 27, 2012 | 04:34 AM
cowboys13's Avatar
Is the sound anything like this?? Im having this problem right now and its annoying!
https://g35driver.com/forums/brakes-suspension/383470-grinding-noise-coming-left-rear-brakes.html
Old Jun 27, 2012 | 04:55 AM
DrewDrew's Avatar
Check and make sure your spring pre load is tight and secure.
Old Jun 30, 2012 | 09:03 PM
daniel3ooo's Avatar
UPDATE: installed new OEM sway bar end links and now all the squeaking/creaking is completely gone! Very happy to say that the sway bar end links were the culprit.
Hopefully the car stays quiet
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
Ray Feta
Aug 20, 2015 08:46 PM
linedr89
Aug 17, 2015 05:11 PM
Fireman07603
Aug 9, 2015 06:00 PM
