Brake Power Booster Questions
Old Jun 28, 2012 | 03:13 AM
Eric@TCGMiami's Avatar
Ok, so I have always complained about the brakes on my 03 G Sedan.
I upgraded to the G37 Akebono's and the power is substantially better but what I cannot comprehend is why the 05 + G35's and even the G37's with standard brakes have nearly the same braking force.
Could it be the master cylinder or brake power booster that make the difference?
Something is truly wrong here.
Suggestions any one?
Old Jun 29, 2012 | 01:27 PM
G35fromPA's Avatar
What do you mean by "same braking force"? Do you mean the amount of pedal pressure required, or the amount of brake force applied to the pads/discs?
Old Jun 29, 2012 | 06:04 PM
The amount of force applied to the rotors.
I also saw on RockAuto.com that there is a brembo specific master cylinder for our G's.
It is slightly larger
Old Jun 29, 2012 | 10:08 PM
G35fromPA's Avatar
The Brembo equipped G coupes of 2003-04 indeed did have a different master cylinder bore, as well as a different brake booster (double diaphragm vs single on the 5AT and on the sedans), but the additional brake torque likely has more to do with the larger diameter rotors on the Brembos, 05+ and G37's. The different brake booster mainly affects pedal feel.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
mushu
Jul 15, 2015 03:55 PM
