Rubbing or bad bearing sound from front wheels.
Old Jul 9, 2012 | 05:42 PM
sworkman31's Avatar
Just noticed about a week ago that I have a strange rubbing sound coming from the front wheels of my 04. Sounded like I was needing new brake pads, so after new brake pads, which did not really need changed, but I went ahead anyway, and rotor turning, i am still getting the same sound. Almost a grinding or wobbling sound at all speeds. Am I looking at bearing problems here? Is this a common problem? This is my first Infiniti car, and I love it, but I really don't want to tear into it without knowing some sort of direction first. Thanks in advance.
Old Jul 9, 2012 | 07:50 PM
joedaddy1's Avatar
wheel bearing or compression rod.. search for it..
Old Jul 9, 2012 | 10:05 PM
G35_DAN's Avatar
Coupe or Sedan?
Old Jul 11, 2012 | 07:03 AM
sworkman31's Avatar
It is a coupe.
Old Jul 11, 2012 | 09:54 PM
G35_DAN's Avatar
More than likely, your front tires are feathered/cupped on the inside edge, causing the loud roaring sound while you're driving at any speed. The faster you go, the louder it gets...and when you come to a complete stop, it seems to intensify.
If your bearings check out OK, then this is most likely the problem.
Old Jul 11, 2012 | 10:05 PM
sworkman31's Avatar
I just noticed the tire being feathered tonight. I guess I didn't realize they would make such a noise. Your diagnosis is spot on!! Nice catch , brotha!! You da man!!
Old Jul 11, 2012 | 10:31 PM
G35_DAN's Avatar
Thanks, man...always glad to help out...
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
