Is it worth it to DIY?
Old Jul 23, 2012 | 06:21 PM
cultcab's Avatar
I need to replace the front pads on my '08 G35 Sport with about 45K miles on it. The dealer's cost is $300 for pads and turning the rotors. It seems like it's probably about $80 for the OEM pads and probably another $20 or so to turn the rotors. Is it worth the $200 to have them do the work? I've done brakes in the past, but I've had some problems with squeaking on the front brakes and I'm worried that if I do the brakes myself and then have problems with squeaking in the future that my warranty will be voided for that issue.
Old Jul 30, 2012 | 07:57 PM
g35pillow's Avatar
You could do it yourself if your are a decent mechanic. You could just take the rotors to a local shop and get them turned for probaly $20 a rotor. So it would save yourself about $150 which is worth it IMO.
Old Jul 30, 2012 | 08:05 PM
Dubi2087's Avatar
As long as you grease the proper areas and BED (breaking the pad in) the pad and rotor you should have no squeaking of problems. Btw you don't always have to get your rotors turned unless you are getting vibes when you hit the brake than that means they are warped, in which I would just replace them. If the pads are worn than just replace them, leave the rotors alone.
Old Jul 31, 2012 | 02:01 PM
VMRWheels's Avatar
+1
$150 saved is a good amount. If the difference was like $40 I might just say it wasn't worth the hassle but $150 is enough to sway a good amount of people.
Old Jul 31, 2012 | 03:59 PM
bluedevils95's Avatar
If you have the know how then yes its worth diy. Youll find it fun that you can work on your own car.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Visionnn
Oct 3, 2015 05:16 AM
Jon81035
Sep 16, 2015 04:58 PM
