thoughts after whiteline comp bushing install
Old Sep 22, 2012 | 12:53 PM
fonzer's Avatar
Did anyone ever experience some noises during turning under slower speeds after changing out your compression bushings to Whitelines'? Mines been pretty noises especially when I parallel park, not so much during regular driving. Thoughts? any fix to it?
Old Sep 22, 2012 | 01:30 PM
Eric@TCGMiami's Avatar
I went back to stock... but to be honest It's not a fair comparison and/or comment as I did not use an OEM part.
I purchased a Carquest aftermarket compression rod and used the whiteline bushing. The Ball joint failed and caused all sorts of noises within 10 minutes after installation/driving.
The bushing was certainly stiffer but I went back to OEM and packed the OEM bushing with 3m Window Weld. It's substantially stiffer now.
Old Sep 22, 2012 | 01:54 PM
JOKER's Avatar
CLUB MODERATOR
the noise you are experiencing is bushing shifting and moving inside it's metal ring around it.
Since it's direct contact between bushing (poly) and metal ring, you get all that noise while it's rubbing.
I went with armstrong bushings, which are similar to whiteline (poly bushings) only they are direct press in into the control arm. Armstrong design prevents vertical movement, but does not eliminate circular. So noise is still present it's just reduced a bit.
I'm just something you have to deal with running this kind of bushings.
They only way I can see to fix it is to attempt to lubricate it
Old Sep 23, 2012 | 02:24 PM
fonzer's Avatar
thanks for the tips guys. im pretty sure my mechanic used the lube it came with, would applying something from the outside (while the bushing is on) would benefit from it?
Old Sep 23, 2012 | 02:46 PM
JOKER's Avatar
CLUB MODERATOR
it does not matter if your mechanic used lube or not, all of that lube is squeezed out long time ago.
If you spray some WD 40 or something I think it will help, but not for long.
Old Sep 23, 2012 | 03:05 PM
gary c's Avatar
I rebuilt my wife's Vette front end with polyurethane bushings, in the beginning it wasn't bad but with a little wear and cold weather it would drive a sane person over the edge. Sounds like a thousand mice makin their squeek noises. Next few weeks I'll be going back to OE rubber bushing regardless of the cost. Even my greaseable poly sway bushings on SLICK make noise, whatever the advantages are the noise isn't worth it....Gary
Old Sep 23, 2012 | 03:19 PM
Frankieg35's Avatar
Id rather put in oem bushings than deal with the squeaking.. lol
Old Sep 23, 2012 | 08:10 PM
My problem was not the rubber bushings. It was the actual ball joint on the compression rod.
Old Sep 24, 2012 | 04:06 AM
fonzer's Avatar
That's a bummer. I wish I did a little more research on this. As I might try to sell my car in the next few months, the noise may depreciate the price, depending who is interested. Or maybe I could just switch back to OEM.
Thanks for everyone's input.
jsimonk
Dec 22, 2023 03:49 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
si_driver
Aug 11, 2015 07:08 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
