Replacing Suspension Components
Old Sep 24, 2012 | 09:37 AM
Georgek99's Avatar
Have a 2005 G35x with about 106K on the clock. Haven't touched anything suspension-wise. Ride seems ok I guess.
Should I worry about replacing struts/shocks?
Thanks.
Old Sep 24, 2012 | 10:13 AM
G35fromPA's Avatar
Yes, it's definitely time to change out the shocks and struts, as useful life is really no more than 50-60k give or take, depending on driving conditions. and you should probably have the compression rod and lower control arm bushings replaced (or the whole components replaced if you can't find a reasonably priced shop to replace just the bushings) as well as those are likely done.
Old Sep 25, 2012 | 02:01 PM
VMRWheels's Avatar
^Good advice. At the very least the shocks and springs. I'd take your car to a dedicated suspension shop as well to inspect all the bushings and whatnot.
Old Sep 26, 2012 | 10:08 AM
Georgek99's Avatar
Thanks for your replies and suggestions.
si_driver
Aug 11, 2015 07:08 AM
TreeFiddy
Aug 10, 2015 06:50 PM
CJay
Aug 1, 2015 03:57 AM
atk08
Jul 30, 2015 03:12 PM
itschuckster
Jul 25, 2015 08:07 AM
