Brake pads, new ultimate thread
Old Oct 3, 2012 | 03:15 PM
BAM!'s Avatar
I'd like to start a thread pertaining to just brake pads. A few friends of mine have G35's and I have no idea which pads to recommend to them. So if you have aftermarket pads, please help me out with some info such as:
What pads do you have now?
What did you have before?
How does it compare?
How much did it cost for the pads?
Would you use these pads again?
Who installed them and bedded them in?
Did you reuse the brake rotors? Were they resurfaced?
Squeaks and squeals?
Dust much?
So pretty much the more the merrier. Now people can have a direction for pad choices.
Old Oct 3, 2012 | 03:34 PM
SDGenius's Avatar
is this only for stock brakes?
Old Oct 3, 2012 | 03:42 PM
BAM!'s Avatar
No this is more for aftermarket pads, and what the differences are. I just wrote a long detailed example until I got a phone call and it dissapeared lol
For example, on my Miata, I had stock brake pads, I was quite impressed when I switched to Hawk HP+ pads. It was about $70 for the fronts. The first time I tested them out with a quick stab of the brakes, I nearly fell out of the seat and had to adjust my harness. No joke! I didn't resurface the rotors but I knew I was going to replace them next set of pads, and I knew that these new pads are aggressive anyways so I didn't bother. I don't want to go back to stock pads after these and am now on my 4th set! The price was more than some Wagner pads at O'Reillys and they dust a lot more but I think its worth the trade off for awesome initial bite and occassional track use. The only other thing worth mentioning is that even though some people with these pads complain that it squeals like a bus, I took some techniques learned as a meachanic and applied them and mine do not squeal at all. I am very happy with them and would recommend them to anyone who drives their Miata hard with some occasional track use or autocross use.*
Old Oct 3, 2012 | 06:22 PM
totopo's Avatar
Stoptech super street
Hawk HP+
Pretty similar to the hawk HP+ i think, though much much less noise (though it might be with my bent metal shims i used with the hawk HP+) Adequate cold braking. I can abs brake at normal daily driving, even in rain. Never gets too cold in cali though. Brake feel not terribly good, definitely better feel after warmed up at the track. Fades at the track in about 5-7 min of heavy usage for me, though somewhat manageable. I think the fade was fairly comparable to the HP+ if not better.
don't remember, got it off tirerack
probably not. Probably will go for more track oriented compounds for next set. I would recommend them though. Good price point.
me
yes, no
yes, though not as much as the Hawk HP+ i had on previously. Mostly squeaks at low speed, like very end of a stop on the street. used plenty of the anti-squeak goo. definitely liveable.
Dust much?
tons, similar to the hp+ and the oem brembo material
Old Oct 4, 2012 | 03:11 PM
G35fromPA's Avatar
Project Mu NS
OEM Brembo compound
Very similar in performance and feel. Great cold bite and solid fade resistance on the street, like OEM Brembo.
Can't remember exactly - about $130 for the fronts
Absolutely
I did
Reused them w/o resurfacing
None
Dust much?
Less than OEM Brembo, but still some. Dust is part of the brake pad compromise. You want great brake performance, you're gonna get dust!
Old Oct 23, 2012 | 03:29 PM
ShayanIK's Avatar
Project Mu NS
OEM Brembo compound
Felt much nicer than OEM. Nice and cold bite and solid fade resistance.
$85 for front, and $75 for rear. Ordered from importdpsspeedshop.com
Depends on price
I did
Reused them without resurfacing
For like 1 month every now and then. After that was pretty quiet
Dust much?
NOTE: I purchased these like 2 years ago, and am in the market to replace them. I was gonna buy another set when I realized that import dps doesn't carry them anymore. Searched everywhere else and they're around $130 or so, consistently. I hear from some that SpeedTech is a great option. They're like half the cost, so I'm wondering if anyone can tell me whether it's a better bang for buck than the Project Mu NS? I tend to drive a bit fast, but I don't take it to the track or anything.
Really appreciate the help.
Old Oct 23, 2012 | 10:55 PM
socketz67's Avatar
Centric 105.0815 Posi-Quiet Ceramic Brake Pad with Shims:
Amazon Amazon
Had used OEM exclusively prior, but cannot believe I waited so long to change.
Brake dust is almost zero and performance is at least equal. Cost is a fraction of OEM.
Centric is also the manufacture of many of the other brands you see promoted here on driver.
Pays to research....
Old Oct 23, 2012 | 11:04 PM
BowWizzel's Avatar
Subed, my brakes squeals loud enough to make ears bleed in the morning.
Old May 30, 2014 | 10:45 AM
ConradoR's Avatar
Hey guys,
I am looking to substitute my brakes (oem brembos).
I DD the car 25 miles highway a day each way, and also a track once a month (4 sessions 25 mins)
I prefer to just keep same set of rotors/pads on and off the track, I realize that this will mean that I won't be able to use track-only pads, but I'm okay with the decreased performance.
I do care about noise and dust, but of course I am not looking for a pad with zero dust because brake fade will be ridiculous at the track. Price is less of an issue.
What pad would you guys recommend? I have heard about HP+, StopTech Street performance, EBC Red/yellow Stuff, Project Mu NS (Have had them and love the streetability, but have never used them on the track), anything else I should buy instead?
THANKS!
Old May 30, 2014 | 03:39 PM
DEMoLITIoN's Avatar
https://g35driver.com/forums/brakes-...uspension.html
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
