how do i get more front negative camber?
Old Oct 12, 2012 | 08:15 PM
Pepper's Avatar
My toe was within factory spec. What are the sizes/offsets of the wheels and the sizes of the tires you're trying to fit?
Old Oct 12, 2012 | 08:38 PM
Lone Wolf's Avatar
Originally Posted by totopo
Well, I thought he might actually have a good reason for negative camber before I saw the pictures.
For daily driver that double for track use, I want my camber to be slightly negative (-2 to -3). (also, bad thing about double a-arm is pain to adjust). My last 2 sets of tires have worn at the outside shoulder first. My rears are max'ed out at -1.8 degrees and they are wearing about even, outside shoulder probably slightly more worn than inside. If i keep driving this car, I would also want to know what front camber arm gives negative adjustment.
But his car I think is too low for track use, so dunno why he wants the negative camber.
I have SPC front control arms and they allow for negative, positive, and caster adjustment.
Old Oct 12, 2012 | 08:40 PM
JOKER's Avatar
CLUB MODERATOR
this actually gives you positive camber, but after this procedure you can get negative camber with just proper application of crow bar.
Lone Wolf's Avatar
Originally Posted by erivera
My car is not for track. I jus want it stanced. Trying to fit some wheels and without pulling my fenders
The reason why I posted a picture is because the first 2 answers I got was "lower it". Jus wondering who would want negative camber on a stock height car?
The tire pictures posted, did u guys try getting alignment? Toe causes more tire wear than camber.
Lone Wolf, what OTHER control arms allow for more camber adjustment? I couldn't find any
How about you search harder. And if OTHER means CHEAPER control arms and camber arms then don't bother buying SPC or SPL as they are they more expensive ones. Try Ichibia lol.
Old Oct 12, 2012 | 08:44 PM
Shanes_G's Avatar
He wants answers feed to him on a silver spoon
Old Oct 12, 2012 | 08:48 PM
Lone Wolf's Avatar
Some people just can't help themselves.
Old Oct 19, 2012 | 02:37 PM
The Stimulation's Avatar
Besides Megan camber arms, there's also Battle Version. I'd go with those personally. I'm not being biased because I used them but because they're easily swappable for longer or shorter arms. Great build quality.
Old Oct 19, 2012 | 02:42 PM
CandlestickPark's Avatar
ill Sedan
My car is not for track. I jus want it stanced. Trying to fit some wheels and without pulling my fenders The reason why I posted a picture is because the first 2 answers I got was "lower it". Jus wondering who would want negative camber on a stock height car?
Your fenders are at least rolled right? Wheel and tire specs of your planned setup?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
