big brakes
So there are other options you can do besides upgrading to a BBK. You can upgrade to better rotors, better pads, SS lines, etc. If you take that route you won't end up breaking the bank. But if your heart is set on a BBK, you can go aftermarket 4 pots from Brembo or Stoptech.
-Nick
-Nick
Isn't this in the V35 tech forum? Then it would be the oem brembos off the g35 coupe sport or 350z.
But anyways, why do you want BBK? It will basically do you no good unless you track your car.
The OEM brakes on the g are pretty good.
And I think people are looking for completely the wrong thing in terms of "feel." People seem to be looking for a super stiff brake pedal, but this is actually not ideal.
the 06 brakes are already improved over the earlier ones. weather or not it's "worth it" is up to you. swapping to OEM Brembo's would open up a lot more pad and rotor upgrade options, 2pc rotors would cut weight improving power delivery as well as disperse heat better for longer. Akebono retrofit would offer BBK looks at a low price. a "true" BBK would offer looks and performance gain at a much higher price.
Again, unless you track your car and can get a performance oriented pad to fade from the heat, a BBK will give you basically NO improvement in braking.
It is basically some cosmetic upgrade for the vast majority of people. Same with cross drilled/slotted rotors. Basically kills your brake pads for no improvements UNLESS you regularly can get performance oriented pads to fade, ie. track conditions.
