Question on G35 coupe SPC rear camber kit
Old Nov 20, 2012 | 03:33 PM
G35DG's Avatar
hey guys,
My question is regarding the SPC rear camber kit on my 2006 G35 coupe 6MT.
I have the car lowered by 1"-1.5", and installed the SPC rear camber kit. After going to an alignment shop, they told me that they can adjust the toe back to 0 degrees but the best they can do on the rear camber was -3 degrees.
After some investigation, I realized that the rear camber arms were installed properly but I did not elongate the toe bolt area (by the rear control arms).
I have two questions:
1) What is the best camber I can get if i go through the extra effort to elongate the toe bolt area?......the SPC box says +/-4 degrees on camber, so does that mean i can actually bring the rear camber back to -1 or even zero?
2) My toe is now back to factory specs at 0 degrees, how detrimental is it to my tires if i continue to run at 0 degree toe and -3 degree camber.
Thanks guys.
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
