Drop vs Camber question
Old Dec 2, 2012 | 12:05 AM
famosobr's Avatar
How drastically would camber be affected with a 1.1-1.5" drop?
Old Dec 2, 2012 | 12:31 AM
bluedevils95's Avatar
I am just spit balling here, maybe -2.5
For me i drop 1 1/4th and my camber was 2.1 in the front and 2.5 in the rear
Old Dec 3, 2012 | 02:59 PM
VMRWheels's Avatar
You're not going to have a ton of camber with a one inch or so drop but you'll definitely need an alignment!
If you want everything to be in spec, look into a camber kit.
Old Dec 3, 2012 | 03:08 PM
terrorx7's Avatar
I've read somewhere (maybe here?) that for every 1" you lower = -.8 degree camber.
Old Dec 3, 2012 | 03:24 PM
If you want the front camber kit i can pull mine off the car and sell them to you. If you not local shipping is on you
Old Dec 3, 2012 | 04:34 PM
AzuMaster's Avatar
Anyone have a pic of a coupe with a 1-1.5" drop with natural camber after the alignment. I've had my S Techs in my trunk for wks terrified to install them without camber kits. I want to see what the camber looks like before I do it. I've searched but there are so many damn threads about this crap.
Old Dec 3, 2012 | 04:43 PM
Tukeeg35's Avatar
You're going to want to get a camber kit man, i dropped my G on a pro kit and my fronts are down to the belts already...waiting to hear back from a member to see if he will ship or I'm just gonna buy through thmotorsports
Old Dec 5, 2012 | 11:18 PM
gary c's Avatar
Your question isn't what we normally see but the simple fact is regardless of how much you lower your G you'll need a total camber kit! This has been discussed since I became a member here and likely before. Your expense for lowering should include springs, SPL camber kit and alignment + install labor. Tires aren't cheap without a camber kit you'll be buying new rubber at least once a year if you drive your G....Gary
Old Dec 5, 2012 | 11:44 PM
KrazySouthG35's Avatar
Maybe it's too soon to tell but I've been dropped on sportlines which is what 2"? It's been a month and there's no signs of wear at all yet and I haven't even had it realigned yet
Old Dec 6, 2012 | 12:15 AM
terrorx7's Avatar
By the time you notice camber wear it'll probably be too late. I had off-camber on my Saab but did not know. I check/look at my tires regularly...one day tires looks great a couple of months goes by and boom...camber wear on inside tire. At which point tire was beyond rotating or salvaging.
Old Dec 6, 2012 | 01:39 AM
DrewDrew's Avatar
-1.5* for every inch dropped.
Old Dec 6, 2012 | 01:24 PM
VMRWheels's Avatar
I don't think visually it will make too much of a difference, if that's what you're worried about. If you want the maximum life out of your tires just buy a camber kit. Otherwise just have your toe straightened out and you should still see a decent amount of life out of your tires. Just be cautious about how much tread you have left and where its wearing.
jsimonk
Dec 22, 2023 03:49 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
