i need to change my rear suspension shocks/struts - oem
Old Mar 8, 2013 | 02:13 AM
rwr's Avatar
rwr
Cool i need to change my rear suspension shocks/struts - oem
hello everyone! - i need to change my rear suspension shocks/struts - im replacing them with another oem rear set ( just want the original look & nice smooth ride! ) 2003 g35 coupe with brembo -
--- whats the torque need to be when i replace shocks/struts ???
how can i access/replace them ??
thank you
Old Mar 19, 2013 | 04:02 AM
bythabay's Avatar
thank you
The torque spec for the rear nut/bolt assembly is 81 ft/lbs and the torque spec for the two upper mount bolts is 21 ft/lbs. The torque spec for the nut that holds the dust boot and all other shock assembly parts is 22 ft/lbs.
Removal should be pretty straight forward, shouldn't have to remove anything other than the said nuts/bolts.
Old Mar 27, 2013 | 10:09 PM
rwr's Avatar
rwr
Thank you
Old Nov 26, 2013 | 09:25 AM
obsdnoblivion's Avatar
Hey you got a part number? I have been unable to find the d spec shocks and struts for my 04 6mt sedan. Or, I haven't been able to find any with part numbers that match what's on the car. I'm hearing a rattle when I hear bumps that I hope is coming from the shocks, like maybe the bushings at the bottom. Or maybe the compression rod bushings, which I think are responsible for my sloppy steering. I have 250K so I suppose it's time. But I just can't figure out which shocks and struts I'm supposed to be getting to begin with.
rezendvous420
May 31, 2020 01:26 PM
kinetek
Aug 3, 2015 04:25 PM
nascarbuff17
Jul 16, 2015 10:23 AM
