Easily accessing upper rear strut adjusters?
Old Mar 13, 2013 | 03:59 PM
2one8's Avatar
Has anyone cut away at the housing of the upper rear strut mounts to gain access to adjustable rear struts? right now I have to drop the rear suspension any time I need to make an adjustment. this spring I will be spending a lot of time dialing in the suspension at the track and it would be hella easier and faster if I didnt have to drop the struts every time.
Old Mar 18, 2013 | 03:21 PM
G35fromPA's Avatar
Not sure what struts you are running, but for my Tokico D-specs, I have the extenders mounted on them. Those run under the rear package shelf and are fed into the pockets under the child seat tether anchor locations. I just removed the tether anchor bolts and if you leave the plastic covers off, you can adjust the extenders very easily.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Th611
Oct 27, 2015 03:48 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
netcbc
Jul 24, 2015 01:59 PM
