03 Coupe Rear tire rub
on
I have a tire rub when I take hard right hand corners and bigger bumps. It only does it on the drivers side rear tire. Also my rear tires wear on the inside edge.
Fenders have been roled and eibach sport springs.
Right now I have 20mm wheel spacers and off set wheels.
Trying to figure out the best way to sovle this problem.
1) Get 15mm spacers and remove some of the rear camber (or get current spacers milled down
2)change the springs so the rear doesn't sit so low
3) or is there something I am missing?
Any ideas will help
Thanks
Brooks
Any ideas will help
Thanks
Brooks
on
on
on
You have two issues, you need to get your alignment corrected and let's assume you haven't installed a camber kit....which you need to do. Camber kit installed and alignment will solve your tire wear issues. Rubbing....you can either get your wheel wells pulled or get smaller spacers, your choice. Camber kits are sold here on our MARKETPLACE under vendor suspension, SPL is what I'm using.
Gary
Gary
