brake schematics
Old Apr 6, 2013 | 05:13 PM
JDM Muscle's Avatar
brake schematics
So, basically long story short my right rear calipers are broken and need replacing. I have been having trouble finding a parts number for my exact set, I have an 03 coupe and apparently there were two versions of the brakes? where would I get a schematic or parts numbers. I have been trying to get a good used pair and have been looking at different 350z brakes and was hoping that I could find a right rear for fairly cheap.
Old Apr 7, 2013 | 05:17 AM
JDM Muscle's Avatar
prease help
Old Apr 7, 2013 | 05:49 AM
herrschaft's Avatar
I'm assuming the "2 versions" are referring to either the regular brakes or the Brembo's.
Old Apr 7, 2013 | 02:26 PM
JDM Muscle's Avatar
I was looking online and apparently half way through 03' they switched the brake sizes?
Old Apr 8, 2013 | 02:46 PM
G35fromPA's Avatar
Here you go: http://www.courtesyparts.com/350z-pa...4_715_806.html
It's for 350Z, but it's the same system.
Old Apr 8, 2013 | 09:57 PM
BuzzLightYear's Avatar
On the G 03,04,05 and 05x all have single piston calipers up front, and 05-06 came with the 2 piston caliper setup up front and larger rotors. All have 1 piston rear calipers, so you can source one from any of those years. 03-04 Brembo's come with 4 piston fronts and 2 piston rears. If you have a non-brembo G the part number you're looking for is 44001-AM800.
Old Apr 8, 2013 | 10:14 PM
dofu's Avatar
20 Year Member
Not sure how different coupes are but non-Brembo sedans have two different part numbers. Some shared rear rotors with the 350Z, others shared rear rotors with the FX.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
