Compression Rod Bushing ??
Old Apr 9, 2013 | 07:04 PM
juice-g35-coupe's Avatar
Exclamation Compression Rod Bushing ??
Ive been looking at post about what is the best thing to do aout replacing your compression rod bushing , But these post are all a bit old most being from 2011 . I was wondering if anyone finally came up with a good bushing that will last a long time and not create so much noise . Also im kind of leaning towards the Spl bushing has anyone here tried them out ???
Old Apr 9, 2013 | 07:21 PM
Row2k's Avatar
20 Year Member
G35 Coupe
whiteline - stiffer, will last, will only make noise when it gets cold...like <40F
SPL - tried it, made tons of noise, spl didn't offer a solution beyond rubber o-rings that made no difference, def improved steering and braking feedback though as well as reduced steering effort.
pick your poison...
Old Apr 9, 2013 | 08:26 PM
Polishthrust's Avatar
Your third option is to use sedan bushings if you want to stick to OEM. Make sure to use bushings from a 2wd not the 4wd.
Old Apr 9, 2013 | 09:00 PM
AuAltima3.5's Avatar
I thought sedan/coupe front suspension components were the same... sans springs/dampers...
Old Apr 10, 2013 | 03:17 AM
6insomnia9's Avatar
Get Energy suspension bushing.
Old Apr 11, 2013 | 11:30 PM
Row2k's Avatar
20 Year Member
G35 Coupe
DO NOT listen to this advice
expect the following with Energy bushings, as there is no play and the compression rod bushing is an articulating point and requires flex, which whiteline and SPL bushings as well as OEM all offer.
Energy bushings:
more info here:
http://my350z.com/forum/brakes-and-s...oly-ftmfl.html
...your welcome
Old Apr 12, 2013 | 04:35 PM
6insomnia9's Avatar
Mine are working great ..
Old May 5, 2013 | 07:05 PM
thanks for the info guys i think ima give Spl a try . I really wanted to stay stock but the price for the stock compression rod and bushing was almost double then Spl :/
Old May 5, 2013 | 07:40 PM
gary c's Avatar
If you want SPL I'm having mine replaced Tuesday with OE bushings. I'll sell them for half of my cost plus postage. Honestly SPL bushings make your car sound terrible, going over the smallest crack on the street sounds like you going across rail road tracks.
Gary
Old May 6, 2013 | 01:48 AM
Gary
Sorry to hear that do they really sound that bad ..most people including my mechanic said they do make noise but no one said it was nothing to great or loud . What bushings are you turning to OEM ???
Old May 6, 2013 | 09:36 AM
gary c's Avatar
I ordered OE bushing two days after installing and driving on the SPLs. Funny part I've had these in my garage for a couple years after reading all the issues members were having with the CRBs, today they're being replaced!
Gary
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
