Best Rear Camber/Toe kit for my setup?
Old Apr 29, 2013 | 07:22 PM
NGK's Avatar
NGK
So I have a 2006 6MT Sedan which I just put:
Rays 19's (245/35 all around)
03-04 Z springs all around (factory struts)
looks great, got the 1" drop as anticipated, but am wondering which rear camber/toe kit I need? I've seen people have bad results with knockoff ones, so I was considering the SPC, Eibach, and Stillen. Whats the difference in the SPC "pro" version, other than angle of adjustment, as in stiffness? and what can one expect to pay these days? $200 +/- ?
Lastly, do I need the camber/toe bolt kit as well, or just the arms?
Thanks for the input, have to buy ASAP
Old Apr 30, 2013 | 06:46 AM
Blue Dream's Avatar
I drove ttrank's car solo
For the rears just about any quality kit will work, just stay far away from Ichiba. The brands you listed are fine with the SPC and Stillen the most expensive. Look at the Eibach kit and make sure you get the toe bolts as well so you can get your rear toe in spec. Z1 has the set for $180 shipped. http://www.z1auto.com/prodmore.asp?m...ng&prodid=2890
Old May 7, 2013 | 04:49 AM
shyun1250's Avatar
Spl
Old May 7, 2013 | 06:47 AM
4DGS's Avatar
Eibach is made by SPC for these parts.
Pick up a set of SPLs. They're expensive but the best on the market.
http://www.splparts.com/
Old May 7, 2013 | 10:15 AM
DEMoLITIoN's Avatar
PBM!! No questions asked
~ lifetime manufacturers defect warranty
~ All steel tubular construction
~ Teflon lined spherical bearings
~ Forged Clamping rod end receiver
~ Forged Clamping double threaded adjuster makes double sure your settings never come loose
~ Super long adjuster threads have the most thread overlap and more adjustability than anything on the market
~ Adjuster away from the subframe, on the knuckle side for easier adjustments
~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion
~ Laser cut reinforced mounting bracket
~ Copper and Gold plated finish
mjfenix
Aug 17, 2017 05:49 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Chattzx
Jul 17, 2015 11:23 AM
nascarbuff17
Jul 16, 2015 10:23 AM
