Small Questions Thread: Brakes and Suspension
Old Mar 25, 2014 | 02:35 PM
  #106
graycar's Avatar
Lca
I am needing to replace a driver left LCA. When looking up various manufacturers, I saw some listed as just left lower and others listed as left lower REARWARD. Is there a difference between these?
Old Mar 25, 2014 | 06:32 PM
  #107
LoSt180's Avatar
Yes there is a difference, the rearward would be what we refer to as the compression rod.
It's best if they include a picture so you can keep them strait when looking this stuff up online.
Old Mar 26, 2014 | 11:52 AM
  #108
DEMoLITIoN's Avatar
Originally Posted by vipster
I shouldnt' be on here reading this bc I'm at work but I am needing rotors soon on my 03 sedan. I dont' want to go with plain rotors and I read here that the 2 piston G/Z front brake setup would be a nice upgrade. what model should I be looking for to get these parts off of? are the front rotors bigger than what I have on there, I'm assuming yeah but I just want to be assured. Thanks in advance.
The 2 piston calipers and rotors come on 2005+ G35,350Z. The rotor size goes from 11.7" to 12.6"
Old Apr 8, 2014 | 11:31 PM
  #109
vipster's Avatar
Thanks for answering, the front calipers are two pistons and rears one. So are 05-07 G/Z rears the same as my 03's? What would be a good price to pay?
Old Apr 11, 2014 | 11:17 AM
  #110
DEMoLITIoN's Avatar
The rears also have a slightly bigger rotor/caliper. You can find the calipers for pretty cheap. It's the pads and rotor choice that are determined by your budget.
Old Apr 11, 2014 | 11:59 AM
  #111
vipster's Avatar
Wish I knew that sooner. I drove four hours to Atlanta on Wednesday to pick up just the fronts. $60 for both front calipers. I was gonna buy all four calipers for $150, but I thought the rears were the same. Thank you though. Now I know to look for some rears as well.
Old Apr 11, 2014 | 03:15 PM
  #112
HypedAndy's Avatar
Will "44060-EG00K" rear brake pad fit on the 03 coupe (non brembo)
Old Apr 15, 2014 | 11:10 AM
  #113
DEMoLITIoN's Avatar
The pads will fit if you already have them but the correct part number is 44060-EG00J
Old Apr 15, 2014 | 11:34 AM
  #114
vipster's Avatar
So what company makes a good set of steel braided brake lines?
Old Apr 15, 2014 | 02:10 PM
  #115
DEMoLITIoN's Avatar
Z1 offers all corners for under $100. You can also go with stoptech for about $40-50 more.
Old Apr 15, 2014 | 03:43 PM
  #116
HypedAndy's Avatar
If they will fit what is the difference from the one you listed and what I listed?
should I worry about anything? (quality difference)
Old Apr 20, 2014 | 11:00 PM
  #117
Inf_Swanga's Avatar
So after reading all the threads about the z/coupe suspension I was still left a bit confused. I an '03 sedan on non-sport suspension, am I able to grab the front springs from any model 350z and replace my front springs, and any model g35 coupe and replace the rear springs? Any help is appreciated, thanks.
Old Apr 24, 2014 | 11:17 AM
  #118
Dr.Bora's Avatar
read through all this and my question hasnt been asked...
i installed coilovers and did the whole rear toe and camber arms, alignment and all that good stuff. I know my way around a vehicle, not superbly but enough to fix some things the right way. after lowering the car i feel the rear end loose when i go over bumps or on the highway. it shifts to the driver side and throws the balance off for a split second and corrects. Also seems to be a tad lower on the pass side rear, when installed i counted all correctly to make sure it was all equal height. Lowered cars before and never had this problem. ive made sure everything underneath is buttoned up and tight and VISUALLY inspected for wear and didnt see anything out of the normal. All is stock aside from the arms and coils. What should i check for next or install to correct this?
04 sedan on stock 17 wheels
Old Apr 30, 2014 | 07:26 PM
  #119
North Chi G's Avatar
I have a question for motordyne sway bar owners.
I just received my set recently and they only came with two bushings. I was under the impression that they came with four but i was told the new ones require you to reuse the other two. I personally dont like the idea of using bushings again. So, my question is are the two that come with the kit front or rear? and are they urethane?
In addition what bushings do you recommend using if i need to purchase some?
Old May 1, 2014 | 02:29 AM
  #120
rnguyen's Avatar
If you get new brakes do you need new rotors as well? Because the last time I got new brakes I did not replace my rotors and now I think they are warped because when I drive at high speeds and start braking, the car starts to shake. Is this a sign that the rotors are warped?
