dragging brakes front drivers side
Old May 13, 2013 | 10:23 PM
Crustybug's Avatar
Car has less than 70k on the clock (05 sedan standard brakes), replaced front brakes, resulted in drivers side dragging and getting hot. Replaced the caliper with a used one, still drags. Pins are lubed, new rotors, pads, and hardware. Gonna lose my mind. Any ideas?
Old May 13, 2013 | 10:42 PM
Crustybug's Avatar
I just find it hard to believe that a hose could be collapsed at the mileage im at, especially with how clean the fluid is.
Old May 13, 2013 | 11:06 PM
joedaddy1's Avatar
Was it the hose?
Old May 13, 2013 | 11:08 PM
Crustybug's Avatar
No idea. I wouldnt think it would be.
Old May 14, 2013 | 03:36 PM
G3531's Avatar
I am having the same issue.
05 sedan, standard brakes.
Replaced pads, rotors, calipers.
Still dragging. Everything is lubed.
Please keep us posted, I'm still trying to troubleshoot too :/
Old May 14, 2013 | 05:21 PM
G3531's Avatar
The only steps to take from here would be to resurface (new) rotors, replace brake lines, or Master Cylinder? I would assume that if this were an ABS controller issue, it would throw an OBDII Code?
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
kinetek
Aug 3, 2015 04:25 PM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
