How well will 350z revised rear springs work on '06 G35 Coupe base?
Old Jul 22, 2013 | 02:32 PM
coinburgh's Avatar
I've been reading through all the posts here and I'm just looking for a slightly firmer ride.
I've read the that almost all 350z's and g35's have a 314 lbs./in. spring rate in the front.
And that the difference is in the rear spring rates 342 (G base) and 427 (revised 350z and G sport).
To me it makes the most sense to just get a pair of used 350z revised rear springs to install on my 06' g35 coupe base.
My question is will this negatively effect any of my other stock suspension components like the rear shocks?
TIA!
Old Jul 22, 2013 | 02:47 PM
LoSt180's Avatar
If you're just looking for a firmer ride, get coupe Sport springs and shocks. The rear shocks are different. 350Z springs can potentially lower the rear of your car 1/2", so unless you're doing the fronts also, stick with coupe springs.
I say potentially b/c that's what the sticky says, I have a Sport model and got no drop in the rear from Z springs, I'm not sure what happens with base model coupes.
Old Jul 22, 2013 | 11:20 PM
Urbanengineer's Avatar
If you are looking for more snappiness, then look into adjustable aftermarket anti-roll bars.
Last edited by Urbanengineer; Jul 23, 2013 at 01:02 AM. Reason: sways are incorrect... thanks blue.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
R350k5
Oct 1, 2015 08:41 PM
ClwMike
Jul 23, 2015 12:55 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
