How to remove the stuck front bearing
Old Jul 28, 2013 | 12:08 AM
mashimario's Avatar
Hello guys,
Any idea to remove the stuck front bearing? I loosened all four 17mm bolts and hammered them but no luck. I even bended the splash guard and hammered the bearing directly, but the thing just does not wanna come off. Since my car is 10 yr old and was in the snowing area for quite long time, and this is the original bearing, I was expecting it would be difficult to remove it. Now I ran out of ideas...
Thanks a lot for your input...
Old Jul 28, 2013 | 02:10 AM
Urbanengineer's Avatar
Don't loosen them all the way... Loosen a half turn at a time and the apply a lubricant like WD 40 or PB blaster. This loosens it up and then repeat the half turn.
Old Aug 1, 2013 | 11:01 AM
MikeDG's Avatar
You need a slide hammer. I rented one from Autozone and they came out with ease.
Old Aug 26, 2013 | 05:06 PM
bythabay's Avatar
are you alternating tapping on the bolt heads?
Old Aug 26, 2013 | 08:49 PM
AARONHL's Avatar
That will get it off no problem, that's what I used
Cajuncowboy
Jun 21, 2021 09:47 AM
Xfactor
Dec 1, 2019 12:52 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
