brembo calipers help
Old Aug 14, 2013 | 01:00 PM
N1GHTMARE's Avatar
Ok so I have an 06 g35 with non brembo brakes what I want to do is get brembos brakes from an older g35 will they fit will I have braking problems abs lights any help will greatly appreciated
Old Aug 14, 2013 | 01:28 PM
redonblack35's Avatar
Ok so I have an 06 g35 with non brembo brakes what I want to do is get brembos brakes from an older g35 will they fit Yes will I have braking problemsYes if you DIY, doesn't seem like you have much knowledge in the matter, brakes aren't something to tamper with on a whim abs lights Is this a question? any help will greatly appreciated
Old Aug 14, 2013 | 01:35 PM
N1GHTMARE's Avatar
Well I want to upgrade the brakes so can stop better my car that I bought is twin turbo and has some power but I feel that this brakes aren't cutting anymore
Old Aug 14, 2013 | 01:40 PM
A TT is a justifiable reason to purchase a BBK which is great don't get me wrong, they preform well, and look sexy. I'm just saying for your safety and those around you on the road, pay someone to have them properly installed. If you plan on tracking your car ever (not just doing awesome Tokyo Drift style slides around corners and races thru the city) then invest in some decent pads and stainless steel lines. And again, have someone install them for you. If you had the $$ to buy a G with a TT then you should be able to shell out the extra couple hundred to have someone install em, test, and bed-in the pads for you.
g35slug's Avatar
Check out the big brake kit from z1 it's a good price for better brakes and a caliper that says infiniti on it
Old Aug 14, 2013 | 01:46 PM
N1GHTMARE's Avatar
Of course am gona pay some one professional to do this job and I bought this car with the engine blown so once I got it repair I had spent a pretty penny on the car so my pockets aren't that deep either but I wouldn't do something if I didn't know how it works so thats why the other g35 brembo is in my price range for right now ??
Old Aug 14, 2013 | 01:53 PM
N1GHTMARE's Avatar
Thanks thats perfect will it be an oem fit
Old Aug 15, 2013 | 07:29 AM
Blue Dream's Avatar
I drove ttrank's car solo
Make sure if you buy Brembos you get the longer bolts so they'll fit correctly.
Old Aug 15, 2013 | 10:02 PM
wallofgrath's Avatar
You can also get the new Akebono brake caliper kits that include rotors, pads etc for just a little more money... and it's new not 80k miles... but I think you will need new wheels to clear the big calipers.
Old Aug 15, 2013 | 10:09 PM
Xet's Avatar
Xet
Brembo's are better performance than Akebono's.
But OP if you are really TT, you should be looking into getting an ACTUAL BBK setup more capable than either of the oem brembo or akebono setups.
seagrasser
May 3, 2022 09:43 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
