Spc camber bolts.. All I need?
Old Aug 21, 2013 | 08:53 AM
ARETHT3's Avatar
Hi...
If I get spc camber bolts will this allow me to adjust my camber and toe... Without the need for arms as well... I tried researching but had no luck...I want to lower my 1.5 inches...
The eBay page said it will adjust camber and toe by 3 degrees??? Is this cheap way??
http://www.ebay.com/itm/SPC-Performa...1ebf71&vxp=mtr
Old Aug 21, 2013 | 09:11 AM
the93owner's Avatar
I think those are just the toe bolts... that will take care of the toe but you will need camber arms to adjust the camber. The complete set should come with 2 camber arms and 2 toe bolts as in this page.
http://www.ebay.com/itm/SPC-REAR-CAM...d26073&vxp=mtr
Old Aug 21, 2013 | 09:45 AM
Frankieg35's Avatar
Toe bolts and camber bolts are the same thing.. It just depends on where u put them.. I have the bolts for toe and as camber bolts because I needed more positive camber from my spc arms.. Both holes need to be elongated with the template they supply to get more positive camber.. If you use them as camber bolts I recommend getting lockouts so the bolts don't slip..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
