Whole car vibrates when Braking
Old Sep 9, 2013 | 08:54 AM
Bassman's Avatar
The whole car shakes when I brake. The faster im going when I hit the brakes the worse it is. At first I suspected the front brakes because I had just replaced the pads and rotors. I just swapped the front rotors again and the rear pads and rotors are about 2 yrs. old. It's not the front brakes.
I do know that something is loose in the front right suspension. It clunks over slow small bumps, possibly the compression rod(?). If the bushing is really bad could this cause the shaking under braking?
Thanks for your help.
Old Sep 9, 2013 | 09:06 AM
WhosUrBuddiee's Avatar
Sounds like your rotors. Go to a mechanic.
Old Sep 9, 2013 | 09:23 AM
ItsA..Gthing's Avatar
Warped rotors
Old Sep 9, 2013 | 09:29 AM
Just because rotors are new, doesnt mean they are not already warped, especially if you bought cheapo ebay rotors.
Did you bed the pads properly?
Old Sep 9, 2013 | 09:36 AM
gary c's Avatar
Members have been posting these issues since the dark ages, there's only one way to locate suspension issues. Find an independent brake/alignment shop and have them inspect brake/suspension parts. Take the time, do the research to find a qualified independent shop in your neighborhood....everyone has as least one! This isn't an issue you want to have the dealership fix unless you have very deep pockets. Just so you know whole car vibrations upon braking is caused by warped rotors.
Gary
Old Sep 10, 2013 | 12:22 AM
eklaharn's Avatar
Just recently had the same issue, my rotors were warped as hell. I replaced all 4 corners with centric rotors and hawk pads. Couldn't be any happier!
Old Sep 10, 2013 | 01:49 AM
Herbbie Hablib's Avatar
Disconnect the negative side of the battery and let it sit a hour, reconnect and your good to go.
Old Sep 10, 2013 | 04:14 PM
SoCal_Scott's Avatar
Had the same problem. 3 of the 4 rotors were warped like crazy. Had them all refinished and had the pads replaced with the akebono performance brake and what a difference!
Old Oct 3, 2013 | 02:23 PM
NOXQCS's Avatar
Most people don't do this when changing their brakes
http://zeckhausen.com/bedding_in_brakes.htm
Old Oct 4, 2013 | 10:28 PM
bEazy209's Avatar
Hit up the mechanic, probably need your rotors turned. Very simple process.
Old Oct 8, 2013 | 01:56 PM
Bassman's Avatar
I just changed the rear rotors and pads at lunch time. Haven't driven it to test out the work. The right rar rotor looked funcky on the inside surface, like the pad was only touching in a narrow band but the pad looked nornal.
I have been thinking that it could be something in the traction control system. If it isn't fixed I'll check the sensors.
Thanks for the new possibility.
Old Oct 9, 2013 | 12:58 PM
Bassman's Avatar
New rotors and pads fixed the problem. The problem rotor wasthe right rear. It was made by Raybestos, ACT grade, their top of the line. Replaced with Raybestos mid grade, profesionnal grade. The bad rotor must have been bad from the start. The inner surface now has a high spot in the form of a ring about midway in the pad contact patch. The pad wear looks normal. The outer edge of the rotor is heavily rusted, with a chunck abouth 1 mm deep and 2 inches long.
mike730
Jan 12, 2018 04:25 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
mushu
Jul 15, 2015 03:55 PM
