Rattling from front right suspension
Old Nov 11, 2013 | 07:11 PM
da1nonley's Avatar
My G35 sedan is making this really bad rattling/cranking noise on the p/s front suspension every time I drive over a bump. Any idea What it could be?
Old Nov 11, 2013 | 07:35 PM
Urbanengineer's Avatar
Video? Audio Recording? Did you see a mechanic? Have you put it on a lift?
Old Nov 11, 2013 | 08:10 PM
da1nonley's Avatar
No. And no lift kit. I did recently have to replace the upper control arm. But the noise still persist.
Old Nov 11, 2013 | 08:44 PM
hurleyguys's Avatar
you had the noise before you replaced the upper control arm? it might be the ball joint. get it in the air and check for loose nuts and bolts. also check all your bushings to see if there are any cracks/tears in them.
Old Nov 12, 2013 | 11:44 AM
G35fromPA's Avatar
Could also be a bad strut
Old Nov 12, 2013 | 11:55 AM
da1nonley's Avatar
I haven't had the chance to get it in the air, but I do hear it a lot when I turn my steering wheel.
Old Nov 12, 2013 | 06:20 PM
da1nonley's Avatar
I figured out the problem, it was a bad tie rod.
Old Nov 12, 2013 | 09:19 PM
What was bad about it? to be specific for future searchers.
Old Nov 12, 2013 | 10:17 PM
Valcrist's Avatar
It had to have been falling out for a tie rod to make a sound
Has it been fixed.
If you had recent work done more than. Likely something was left loose.
If it was not something left loos, sounds more like a sway bar link or ball joint.
Old Nov 13, 2013 | 12:31 PM
DEMoLITIoN's Avatar
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
tiguy99
Mar 1, 2016 11:42 AM
Fireman07603
Aug 9, 2015 06:00 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
