best sway bar kits for 03 sedan ??
Old Dec 26, 2013 | 11:30 AM
carlos27's Avatar
Hi guys I'm just trying to figure out what sway bar kit to buy I was thinking of the adjustable ones but I wasnt sure can anyone help kinda new to rear wheel drive cars lol I used to drive a g20 lol let me know thanks
Old Dec 26, 2013 | 11:44 AM
infinitidude's Avatar
I have Hotchkis front and rear sways and they are night and day over factory sway bars.
Old Dec 26, 2013 | 10:18 PM
carlos27's Avatar
What size are they ?
Old Dec 27, 2013 | 01:46 PM
Not 100% sure on the size
Old Dec 27, 2013 | 02:09 PM
JaE35's Avatar
Moderator
G35 Sedan
Not really a "best" for the sedan just make sure when you find a set get aftermarket end links as well if you're higher mileage because sways will wear them out quick. Expect a huge improvement going from stock to any aftermarket sways. I highly recommend this mod. Here's a great deal on sale now in the marketplace https://g35driver.com/forums/steerin...-bars-f-r.html
Old Dec 28, 2013 | 01:02 PM
5150DS's Avatar
Still on mine since 2005...work great.
Old Dec 29, 2013 | 12:17 PM
srv2nv's Avatar
G35 Sport
Stay away from Stillen, through my research into aftermarket sway bars for the G35 I've found them to be notorious for cracking and breaking.
And I can tell you from first hand experience that their customer service and warranty is only good until you buy their product, then expect no help and poor communication if your part breaks or falls apart because of cheap materials.
Old Dec 29, 2013 | 02:02 PM
dofu's Avatar
20 Year Member
Like others have said, it doesn't really mater which you go with, any aftermarket sway bar will be a night and day difference.
The things I would look for in a sway bar is hollow bar with a larger diameter, and adjustable.
With that said, Hotchkis has one of the largest diameter in an adjustable sway bar, but Progressive isn't bad either.
Old Dec 30, 2013 | 08:48 AM
carlos27's Avatar
So it seems hotchkis is the best. Thanks a lot guys
Does anyone have any reviews for tananbe sways ?
Old Dec 30, 2013 | 10:09 AM
gary c's Avatar
There are many quality sway bars available, I've been running Stillens since '06. Motordyne sways also have a good reputation. Whatever you end up buying after market endlinks will make your sways work even better since OE endlinks are weak. Powergrid endlinks work best, I had quality issues with other brands coming loose!
Gary
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
