03 G35, gold dust on wheel?
Old Dec 29, 2013 | 06:10 PM
Chikken's Avatar
Hey guys, new here. My 03 g35 has gold dust all over the rear pass side wheel. I don't see anywhere where the caliper could be rubbing (I have gold brembos) and I'm on stock wheels. I also hear a grinding ish noise when braking but assumed I just needed new pads ans rotors. The gold dust is new though. Any ideas?
Old Dec 29, 2013 | 06:24 PM
PAIXAO's Avatar
Pads and rotors. Replace them
Old Dec 29, 2013 | 06:49 PM
TORETTO's Avatar
Sorry I had to.
Old Dec 29, 2013 | 07:34 PM
Mike04x's Avatar
Def there's no meat left on those pads
Old Dec 29, 2013 | 08:35 PM
Chikken's Avatar
Yeah I plan to replace them, but I dont understand why that would cause gold dust on just this wheel. The other wheels are fine. But I do believe there to be an issue with the caliper as well; it "grinds" whenever the wheel is spinning now. Going to have it checked out tomorrow.
Old Dec 30, 2013 | 12:24 PM
Mustang5L5's Avatar
Just guessing here. Hopefully you can update and let me know if i was right....
One of the caliper slide pins has seized, causing the caliper to lock in place. As a result, only the inner pad is able to press against the rotor. What has happened is the inner pad has worn down to the backing plate and now the plate is contacing the rotor. The gold dust is rust/pad/rotor material that is being scraped off and flung around the wheel.
Put a finger on the backside of the rotor and feel the surface. Is it smooth, or is it starting to get rough?
Depending on how badly the brake caliper slide pin is seized, you might not be able to free it. Replacement calipers are cheap on rockauto.com
I'd recommend pulling the rim off, and inspecting the brake by unbolting the caliper and checking pad condition as well as inspecting both sides of the rotor.
Basically...been there, done that. I would be your pedal is a little soft as well. If you double pump while braking, does pedal response improve as well?
Old Dec 30, 2013 | 01:34 PM
hurleyguys's Avatar
i am with mustang on this one. need to change ur pads ASAP
Old Sep 29, 2014 | 11:54 AM
Speg80's Avatar
I too have a seized slide pin, any way to remove it? Noticed noise when turning the wheel and at low speeds, inner pad is worn while the outer looks new. I have ordered new pins.
Old Sep 29, 2014 | 01:12 PM
Mustang5L5's Avatar
Honestly, i'd just order a reman calipers. I beleive they were ~ $50 or so plus core on Rockauto.com
Having messed around trying ot free a badly seized pin, the inner bore gets so corroded that the problem just comes back pretty quick.
Old Sep 30, 2014 | 01:06 AM
Speg80's Avatar
Thanks
Old Sep 30, 2014 | 08:30 AM
WILLIE BEANS's Avatar
check your e-brake .. it might not be fully pressed in but it can be slighty pushed in and applying some pressure.
it can happen
Old Oct 11, 2014 | 07:53 PM
_Nick's Avatar
I let my pads go down to the metal on my old Mercedes and there was fine metal "dust" all over the rims that oxidized and looked very similar to your picture.
Check the meat on the pads. The face of the rotors don't look too bad but the edge of it looks ****. Plus I think I can see some metal shavings on the top of the caliper.
Old Oct 12, 2014 | 02:19 PM
Blue Dream's Avatar
I drove ttrank's car solo
Nick you realize the OP was from almost a year ago right?
Old Oct 12, 2014 | 03:07 PM
_Nick's Avatar
I didn't, sorry for the bump
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
