Brake Specs
Old Jan 13, 2014 | 04:26 AM
g35SedanSC's Avatar
Exclamation Brake Specs
Does anyone have the chart/list of the brake/rotos sizes?
This is the 350z chart,is it the same for the g35?
2003-2005 Non Brembo:
Rotor size Front: 296mm x 24mm
Rotor size Rear: 293mm x 16mm
Caliper Front: Single piston
Caliper Rear: Single pistion (#192793)
2006+ Non Brembo:
Rotor size Front: 320mm x 28mm
Rotor size Rear: 308mm x 16mm
Caliper Front: Dual piston
2003+ Brembos
Rotor size Front: 324mm x 30mm
Rotor size Rear: 322mm x 22mm
Old Jan 13, 2014 | 03:35 PM
saywat?'s Avatar
hit up buybrakes.com. they got all the specs when u select stoptech replacement rotors
Old Jan 13, 2014 | 04:47 PM
LoSt180's Avatar
The G35 uses the same brakes/rotors, however 05 models is when the changes happened.
Here's a G35 chart I just made up:
2003-2004 Non Brembo:
Caliper Rear: Single piston (#192793)
2003-2004 Brembos
2005 AWD models (same as 03-04 base)
2005-2007 (2006+ AWD models use these also)
Old Jan 13, 2014 | 06:03 PM
g35SedanSC's Avatar
Thank you so much!
Both of you helped me a lot.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
DRG35R
Sep 16, 2015 05:33 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
