nice new clunking sound from drivers side
Old Feb 23, 2014 | 12:12 PM
AARONHL's Avatar
That sounds like an upper strut mount or a compression arm BALL JOINT (not bushing)
Old Feb 23, 2014 | 08:21 PM
willmkent's Avatar
ok, thanks man. I am gonna take it to my buddy who just hasn't had time to look at it yet. I hope it's a decently easy fix, I can't stand the sound anymore
Old Feb 23, 2014 | 08:26 PM
ScraggleRock's Avatar
Just so you all know, I will soon have brand new mevotech arms with energy bushings pre greased and installed. I can ship them to your door so you have the new ball joint AND poly bushings. They'll be wrapped and ready to install so you experience no down time. Pop the old ones off, pop the new ones on. PM me if interested.
Old Feb 24, 2014 | 10:12 AM
willmkent's Avatar
That actually sounds pretty good! When I changed all my pads and rotos out, the suspension parts that I could see really well looked new and well maintained... I guess I'm just surprised but with this weather, I don't want anything to so with DIY work
Old Feb 24, 2014 | 10:28 AM
DEMoLITIoN's Avatar
https://g35driver.com/forums/brakes-...eshooting.html
Old Feb 24, 2014 | 07:51 PM
willmkent's Avatar
dude that thread is awesome! thank you!
Old Sep 8, 2014 | 01:39 AM
Remington's Avatar
Curious what the issue ended up being, and the fix.
Old Sep 8, 2014 | 07:36 AM
willmkent's Avatar
The sounded ended up being the compression rid, I replaced both in the front as well and the inner and outer tie rods, shocks and struts, etc etc
Old Sep 8, 2014 | 10:13 AM
Remington's Avatar
Thanks. Did you replace the upper strut mounts or seats?
I am trying to identify a clunk that is very similar to your recording.
Thing is, my compression rod and transverse link are only 1 year old. Upper link (camber arm) and tie rod ends were loose, and just replaced.
Pry tests didn't reveal any loose joints.
Old Sep 9, 2014 | 07:13 AM
willmkent's Avatar
Yes I replaced my mounts as well. When my mechanic went though the car he told me the sound was 100% the compression rod where it bolts up. I didn't see if for myself so I can't completely describe it but I damn near replaced everything on the car so I can't narrow it down. I did all the tie rods, rack and pinion, sway link, compression rods, shocks struts and adjustable camber arms. It's pretty much a brand new suspension underneath
Old Sep 10, 2014 | 12:49 PM
Remington's Avatar
Thanks again. I am nearly there too. I will keep going 1 piece at a time til I get rid of all the clunks.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
vstypicals
Jul 20, 2015 10:55 PM
cyrus32
Jul 18, 2015 06:22 PM
