Steering question
Old Feb 25, 2014 | 02:48 PM
Frankieg35's Avatar
Steering question
My steering feels notchy at times, more so when im going slow or right after I put it in gear, any ideas?? Im pretty sure my toe in the front is a little off cause my tires are choppy.. Im thinking a bushing..
Old Feb 25, 2014 | 08:43 PM
Urbanengineer's Avatar
Same issue here.
My garage lift is halfway up (two posts, Gawd this is taking forever to set anchors), once it's done I'm going under to find out what it is.
Old Feb 27, 2014 | 10:45 PM
Frankieg35's Avatar
Bump
Old Feb 28, 2014 | 12:28 AM
Pepper's Avatar
Could be the angle joint piece. Mine went bad like 2 years ago. Replaced it and it drove perfect after that.
http://www.z1motorsports.com/product...oducts_id=3238
Old Feb 28, 2014 | 01:05 AM
Was not expecting a steering knuckle. I'll check that thanks! (He doesn't have a G and knows all this...!)
Old Mar 1, 2014 | 07:44 PM
Frankie, I'm adding pictures and a little explanation right now...
Old Mar 1, 2014 | 08:30 PM
There are a few places you are going to want to check. If you have the same or similar issues with your underbody connections that I do then we can collect the issues point to one specific piece.
I had some cracks in my suspension bushings. The pictures are below. They were on the transverse link (picture 3) and the LCA (Picture 2). The compression rod bushings were looking dry. I added automotive grease (tube kind) to all of these bushings for the time being.
The parts that I noticed were chalk dry were the steering knuckle (picture 1), the rod end of steering wheel engine side, & the steering rack (what I could see with this one). Those were lubed with an automotive grease (in a tube kind).
If you really want to replace the steering rack: https://www.rockauto.com/catalog/x,c...35%2B3.5L%2BV6
Looking at other threads on our issue points to a bad steering rack or tie rod:
https://g35driver.com/forums/g35-sed...ing-wheel.html
Old Mar 1, 2014 | 09:06 PM
Having issues with pictures. here is the dry steering knuckle.
Old Mar 2, 2014 | 01:46 PM
See lower left part. This is the knuckle.
Old Mar 6, 2014 | 05:20 PM
Frankieg35's Avatar
Thanks for the info.. I still gotta get mine checked.. I noticed a slight clicking sound when I turn the wheel to the left while I'm parked.. I'm at 96k miles and lowered most of the time so I'm sure some bushings are bad..
Old Mar 6, 2014 | 11:08 PM
Reporting back, I put automotive grease (pressed in with index finger anyways) into all the bushings and ball joints I could find on the front end.
It is a world of a difference! No popping, clapping, clipping, or tinging. I'll give it a week .
Old Mar 9, 2014 | 09:16 AM
Frankieg35's Avatar
I found my problem.. My front driver side compression rod bushing isn't seated in my lower control arm.. #lowerdcarproblems
Old Mar 9, 2014 | 11:17 AM
OP delivers!
Old Mar 9, 2014 | 12:08 PM
Frankieg35's Avatar
Old Mar 9, 2014 | 12:41 PM
Frankieg35's Avatar
Is that the compression rod bushing??
