BC Coilovers
Old Mar 14, 2014 | 10:37 PM
thirtyfizzle's Avatar
BC Coilovers
I am purchasing BC coilovers soon. I was wondering if I need to purchase any other suspension parts after the coilovers?
Old Mar 15, 2014 | 01:50 AM
jonavalos93's Avatar
yeah, camber kits and you'll need toe bolts
Old Mar 15, 2014 | 02:46 PM
Thaaa_king's Avatar
does anybody know how low these go? im looking to purchase these but i want to go REALLY low
Old Mar 15, 2014 | 02:59 PM
the fronts will slam but the rears only go so low, because they are not true coils in the rear so if you are looking to go "REALLY LOW" these aren't for you, buy Stance coil overs
Old Mar 16, 2014 | 10:46 PM
What's the best place to the get coilovers from
Old Mar 16, 2014 | 11:30 PM
look on Facebook, Adam Race Consulting Agency. He's the best around! Knows his suspension better than anyone else!
Old Mar 17, 2014 | 06:34 PM
Bump! So are camber kits a must?
Old Mar 17, 2014 | 11:25 PM
Lartytiejdke3's Avatar
Yes. Wait for somethin on here lightly used to show up to save $$. Dropping $500 for the front and rears is crazy
Old Mar 18, 2014 | 11:52 PM
Man thought camber kits were just a personal reference. If I don't go that low they are needed?
Old Mar 19, 2014 | 04:07 AM
xFALCONS7x's Avatar
Technically you don't need them but your alignment is gonna be way out of spec and your car will handle like garbage. If you put a lot of miles on your G then its well worth just getting the camber kit. It pays for itself eventually in tire wear alone!
If your only dropping your car 1-1.5" then you should be fine with just a rear camber kit and toe bolts. Any lower than that and your def gonna want a kit for the front.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
