180k Miles 04 Coupe - Shocks, Struts, Springs question.
Old Mar 28, 2014 | 11:25 AM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Gdirtyfive55
Front Strut for G 35 Coupe
Old Mar 28, 2014 | 02:22 PM
coffeysm's Avatar
I put those on the front pretty nice.
Old Mar 28, 2014 | 04:53 PM
ScraggleRock's Avatar
se
I'm assuming you didn't read the link that I posted, so ill quote it.
"The major difference between shocks and struts is that astrut is a structural part of the vehicles suspension system where a shock is not. A strut is also crucial part of the vehicles steering system and greatly affects alignment angles. Camber and caster angles are usually adjusted right on the strut itself. A strut is also a pivot point for the vehicles steering system and contains a coil spring. Because of this an alignment is always needed when replacing a strut. This is also the reason that struts are typically more expensive than shocks."
Our shocks are merely there to dampen. They are not a critical part of the steering system, nor do they affect camber and caster. Furthermore we have a 4 wheel independent multi-link suspension. Multi-link suspensions use shocks,, and double wishbone suspensions use struts. It doesn't matter what it looks like.
Old Mar 29, 2014 | 02:28 AM
JOKER's Avatar
CLUB MODERATOR
they don't last that long with lowering springs.
Old Mar 29, 2014 | 02:29 AM
JOKER's Avatar
CLUB MODERATOR
se
Sounds good man.
I'm just going to off of what manufacturers call their own product.
In this case for G35 they call it a strut.
Old Mar 29, 2014 | 05:57 PM
coffeysm's Avatar
I bought the ones made for the G35 and used the OEM springs.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
xplosive1
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
cyrus32
Jul 18, 2015 06:22 PM
Scredeur4
Jul 17, 2015 06:30 AM
