Car Shaking - sometimes
Old Oct 7, 2014 | 08:25 PM
hdmark's Avatar
Hoping someone has had a similar problem or knows whats up with my car
I just got new tires about a week ago (and an alignment back in march maybe? ) and started noticing the steering wheel and a little bit of the whole car shaking sometimes. it wont be all the time, and not at certain speeds. ill be driving and the steering wheel will start to shake and then a few miles down stop. the car also does track straight so i dont think the camber is out of whack. i thought it could be bad tire balancing but i figured then it would shake all of the time..
any help is greatly appreciated!!
Old Oct 7, 2014 | 10:51 PM
bchalks's Avatar
Could be a tire out of balance. They might have had a rookie balance it and he f***ed up.
Go to seers and get a free alignment check just to make sure its not your alignment.
Old Oct 7, 2014 | 10:54 PM
hdmark's Avatar
Think they have a rack that can take a lowered car ?
Old Oct 7, 2014 | 10:56 PM
bchalks's Avatar
Depends where you go. Also how low are you?
Old Oct 7, 2014 | 10:59 PM
hdmark's Avatar
Inch drop ish ? On oem 18s
Old Oct 7, 2014 | 11:13 PM
bchalks's Avatar
Should be fine at any place. Bring some 2x4s just incase you need that extra lift to get on the rack.
Old Oct 13, 2014 | 03:07 PM
aussie983's Avatar
Check your compression rod bushings.
Old Oct 13, 2014 | 03:16 PM
hdmark's Avatar
^^^^ were just replaced last summer with poly.
getting my tires re-balanced tonight . hoping the guys in philly just did a shitty job
Old Oct 13, 2014 | 03:26 PM
gary c's Avatar
Chances are very good after you had your tires balanced you lost a weight, rebalance should fix the vibration...Gary
Old Oct 21, 2014 | 10:00 PM
Heytheremr2's Avatar
I agree that it could either be a bad balancing job or a wheel weight fell off. However, in my opinion, I would assume that would make it consistently shake at the same same speeds
Old Oct 22, 2014 | 12:06 AM
hdmark's Avatar
Update !!! Got the wheels rebalanced . The guys in philly had screwed it up! Drive amazing again ! Between the new tires/balance and new brakes... car feels new
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
