Adjustable range of factory camber?
I am deciding on suspension components and I can find what the drop limits are for the factory adjustments. I really only want between 1"-1.5" will I still need adjustable control arms and chamber bolts? I have seen arms for sure between 1.8"-2" but nothing about the chamber bolts.
Anything over 3/4" is recommended to get rear camber arms, toe bolts, and front adjustable camber arms. Yes there are cases of people getting by and doing the run around, but why live on the edge? If whoever can align your car can dial in your toe as close to zero, then you will be fine.
Consider the cost of quality tires, then decide how often you want to replace them! Any time you lower our G35s you're going to need a camber kit! The next issue will be finding an alignment shop that knows how to adjust modified suspensions back to OE specs. Stores like Goodyear and Firestone with their life time alignment warranty's don't have a clue. ![OHBOY](https://g35driver.com/forums/images/smilies/ohboy.gif)
Gary
Gary
I think he means actually unmounting them and putting the left front on the right front wheel and vice versa. So they're still going the same direction, but now the inside wear is on the outside. You can't do this with asymmetrical tires tho.
