Steering Wheel Vibration?
Old Mar 18, 2015 | 03:59 PM
JHereth22's Avatar
So lately my car feels unsafe. Anything above 60. Steering wheel vibrations and lots of them.
I've gotten all 4 tires balanced(by my brother who works at Honda)
Replaced both outer tie rods, and one of the inner tie rods. Fresh alignment.
Honestly it feels as if the wheel is going to come off. Help....
Old Mar 18, 2015 | 04:47 PM
JHereth22's Avatar
Come on someone. Help out here. I'm about to take a long *** road trip
Old Mar 18, 2015 | 04:58 PM
JHereth22's Avatar
Also replaced front brake pads, and rotors.
Old Mar 19, 2015 | 04:15 PM
hdmark's Avatar
dent in a wheel?
low tire tread?
your brother isnt very good ? (jk)
Loose wheel nuts? (probably not...)
bad control arm bushing?
Old Mar 19, 2015 | 04:20 PM
JHereth22's Avatar
All the tires actually have good tread, but i think it is a dent. Buying some G35 Sedan 5 Spoke 17in to check if dent.
I didn't think LCA bushings would cause this?
Old Mar 19, 2015 | 04:25 PM
hdmark's Avatar
meant to say compression arm. and no idea if it would, im just throwing out things that i know cause issues to the suspension
Old Mar 19, 2015 | 04:34 PM
JHereth22's Avatar
Haha well mine are shot
Old Mar 19, 2015 | 04:50 PM
gary c's Avatar
Vibrations are caused by out of round tires, out of balance or alignment. It their balance machine hasn't been calibrated within the last year chances are good it's a balance issue. Find a tire shop and spend the $$ to have it checked! It's too possible if your Brother didn't secure the weights one may have fell/flipped off causing the out of balance issue!
Gary
Old Mar 19, 2015 | 04:54 PM
JHereth22's Avatar
Honda just got the newest coolest one. Not the machine or the one balancing. Lil bro is rather good at his job. But Im buying some different rims to see if it is a bent rim
Old Mar 19, 2015 | 04:58 PM
gary c's Avatar
I don't buy the bent rim have your tires rebalanced! If your Brother is as good as you think, he would have seen an out of round wheel while doing the balancing...it's very obvious...Gary
Old Mar 19, 2015 | 05:01 PM
JHereth22's Avatar
Well here's the thing. He balanced them, re balanced them, but he's the one who said it was a little off and hard to balance. We checked and they look outta line.. Fml. Ive spent 15hrs under this car just in 2 days
Old Mar 30, 2015 | 11:58 PM
350gt4k's Avatar
Im on the same boat. I have changed all LCA bushings, Compression rod, Tein tie rods, Bilstein Struts, Swift springs, SPC camber kit, and the Knuckle ball joints, balanced all tires (2X) alignment (2X) and have checked for cracked rim. I have the same vibrations above 60 mph and its been driving me crazy!!!.
The last thing i can think of are my end links or rotors.
Old Mar 31, 2015 | 12:48 AM
JHereth22's Avatar
Haha well glad I'm not the only one. Fixing some bushings tomorrow and getting new rims and tires Wednesday
Old Mar 31, 2015 | 08:23 AM
hdmark's Avatar
wheel bearings? (again just tossing stuff out there)
Old Mar 31, 2015 | 09:55 PM
JHereth22's Avatar
Didn't think about that....
jsimonk
Dec 22, 2023 03:49 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
