Front lower ball joint...... need some pinions on them!!!
Old Apr 20, 2016 | 03:46 AM
azslider86's Avatar
So my ball joints need to be replaced I have been puttin off cause it's not critical repair yet the noise is more of annoying noise if anything but been looking into getting the z1 front lower ball joints. So a little bit again I came across Megan Racing MRS-NS-0350 G35 Roll Center Adjuster. There the exact same parts just made differently and the megan 1s are twice as much as the z1. Is the megan ball joints any good or better then z1 ball joints??? I am assuming there more expensive just cause they have the megan name on them. I would like to hear others pinion on the aftermarket ball joints......
Old Apr 20, 2016 | 10:23 AM
LoSt180's Avatar
I picked up a set from CZP. Apparently the 05+ has a different ball joint and CZP is the only one I've found that sells the proper one. I'm not set up for racing, so roll center adjustment is unnecessary.
Old Apr 20, 2016 | 12:17 PM
nizzan4u2nv's Avatar
If you car is fairly low is can benefit from it as it corrects issues with suspension geometry on lowered vehicles.
Old Apr 20, 2016 | 07:45 PM
coffeysm's Avatar
I used Deeza from RockAuto, I think they were 40-50 bucks a piece. Still going good!
Old Apr 20, 2016 | 11:00 PM
azslider86's Avatar
Currently my car is not low at all still at factory height on factory spring I am going to be doing z oem springs and struts on it soon and adjustable up control arms just have to buy the ball joint now. Not really looking into slamming it on coilovers just yet. Still undecided if I want to keep it as a daily or turn it into a track car yet.
Driver_Dave
Dec 22, 2017 12:05 PM
Metalp3n
Dec 24, 2011 06:58 AM
orl-g
Florida G Club
16
Mar 28, 2011 03:05 AM
badnblk
May 14, 2010 09:50 AM
