Brakes caliber
Old Feb 15, 2017 | 07:12 PM
cullyisgully's Avatar
Brakes caliber
Hello guy so I have a G35 07 6 speed and when im on a hill in neutral my car does not role back cause one of my brakes caliber I think is frozen or is there any thing I can do to try and fix it or should I just replace it ? It works some times but its getting worst. I live in NYC and do you think the cold is the problem any info will help me on this problem
Old Feb 15, 2017 | 07:18 PM
Urbanengineer's Avatar
remove slide pins from calipers and clean them. Then, apply new grease and re install. See if your problem goes away.
Old Feb 24, 2017 | 08:03 AM
OK thanks do I have to take the line off or I can fix it with out taking if off ?
Old Feb 24, 2017 | 09:23 AM
coffeysm's Avatar
You don't need to take the lines off unless you replace a caliper. I think it's a 14MM bolt, loosen them off, and then use a synthetic or silicone grease on the pins.
Old Feb 24, 2017 | 09:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
It's a caliper homie, not a caliber.........and I'm pretty sure there's more than 1 guy on this forum.
Follow the above advice and hopefully that'll fix your issue. If you need a new caliper RockAuto has them priced pretty low and they're re-manufactured OEM's I believe.
Old Apr 14, 2017 | 06:07 PM
ok So It's my driver back side that is giving me the problem. I will do my brakes and clean and silicone tomorrow and take some pics and try to post on here but im having problem uploading pics on this web site
Old Apr 16, 2017 | 01:19 PM
Ok so I cleaned them and new grease and the one side that was giving me the problem is still doing it but even hared now with the new brakes. So Im going to just change the 1 side or should I do both and get from the auto part store, off ebay or get some kind of sports ones does it even matter on witch kind I get ?
Old Apr 17, 2017 | 04:09 PM
coffeysm's Avatar
I'd only replace the bad one.
