Front Crossmember Subframe Brace Replacement, Opportunity to Upgrade?
Old Feb 8, 2022 | 10:30 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Anytime I get into fasteners like that I usually hit them with some cold galvanizing spray when everything is reassembled just to make sure when I take them off again in the future they aren't rusted up. Unfortunately cold galv is a grey color but it's on the bottom of the car so it doesn't bother me.
Old Feb 14, 2022 | 05:15 PM
2k8Xs's Avatar
Silver Xs, exhaust, 09 sport brakes.
I applied some duplicolor rust barrier to the 2013 "batwing" and then applied a quart of SEM rust stop to all the frame and support problem areas. Only 2 bolts absolutely wouldn't come out even with extractors ( semetrically both on the control arm mount) so I'm running 6 bolts instead of 8 underneath. But yeah the entire original assembly came out in 3 pieces and an endless pile of rust chips.
I replaced the rear stay bar while I was at it. For anyone doing that with the tires off the ground, make sure you support your rear crossmember. Almost found out the hard way on that one.
I'm not sure if it was just my local Infiniti dealer but I got the stay bar for around $90 on sale.
Old Feb 19, 2022 | 10:45 AM
cleric670's Avatar
BANNED!!!
Lol, I'm calling it the batwing from now on.
Old Feb 19, 2022 | 04:25 PM
2k8Xs's Avatar
Yeah I thought that was funny when I found out almost every salvage yard called it that. Car-part.com is an awesome resource to find salvage yard parts for anything.
Old Mar 30, 2022 | 05:03 AM
Daniel42087's Avatar
Infiniti G35x awd
Originally Posted by towerdog81
did you have any luck finding this brace? I just got under mine to find my oem brace also very rusted. I would like to get a nice replacement if possible also.
look on amazon ... Thats where i last seen that aftermarket part
Old Mar 30, 2022 | 05:07 AM
Infiniti G35x awd
Unless this was a dedicated track car you're not going to feel a difference, this chassis is extremely rigid with the OEM components. Just buy another OEM front brace and coat it in a flexible sealant so it won't rust out in the future. Bed liner, chassis undercoat, urethane, something that is abrasion resistant and flexible. It won't be as pretty as a custom made powdercoated piece but it's going to perform the same.
how complicated is the swap? Looking at doing mine shortly as it looks like pic above. LOL.
Old Oct 11, 2025 | 04:59 PM
mjtct's Avatar
G35x
Just replaced the Batwing today on my 08 G35X. Purchased from Infiniti and repainted with Spray MAX 2K Black Satin. Was easy but outermost bolts had disintegrated. Had to use a cut off wheel to create a slot to chisel those outer bolts free. I had purchased the M10-1.25x 30mm fasteners but found you actually need M10-1.25x 25mm. Had to reuse the bolts that connect to the lower control arms because 30mm were too long. Other fastener locations will accept 30mm.
It seems this part could be experiencing galvanic corrosion as it connects steel to the aluminum lower control arms.
Sieveboy
V36 General Tech Questions
Jan 19, 2016 07:39 PM
Gashed
Aug 19, 2012 12:35 AM
RandomHer0
Interior
Jul 26, 2007 09:12 AM
