Camaro SS Brembo on G35?
Old Oct 31, 2017 | 09:45 PM
Idris Yusuf's Avatar
I found a set of Brembos from an SS Camaro locally for reeeaaally cheap and was wondering if anyone knows if any adapters were made for this type of conversion, or what I would have to do to make this work - if at all possible (change rotors as well?)
I've seen some FRS owners do this with Brembos from a Cadillac ATS, so I was wondering if this could be done in a similar manner for the G35 coupe - or if I'm better off just sticking with the Akebono swap.
Old Oct 31, 2017 | 09:51 PM
Edgarc6789's Avatar
Akenono swap
Was really easy
And there's kit for It
I never heard of a kit for the camaro ones
Old Oct 31, 2017 | 09:55 PM
Yea that's probably a stretch lol, thanks!
Old Oct 31, 2017 | 09:59 PM
Originally Posted by Edgarc6789
Akenono swap
Was really easy
did you change your brake lines, or just kept oem
Old Nov 1, 2017 | 12:41 AM
Edgarc6789's Avatar
i have my oem lines
but im most likely putting the ss lines on
Im just trying to see what difference it will make since they already grab pretty good
Old Nov 9, 2017 | 11:17 AM
LoSt180's Avatar
I tried looking into the Cadillac CTSV brembos and found that too much material on the spindle has to be removed/ground down in order for a bracket to fit properly. This would be using 355mm G37 rotors.
Brackets do exist to bolt up Jeep SRT8, as well as Porche (17Z/18Z) 6-pot calipers, to the G35/350Z chassis.
Akebono is the most common, and path of least resistance. Other options do exist, just not the fairly cheap GM calipers, lol.
Old Nov 11, 2017 | 12:14 AM
Urbanengineer's Avatar
^Always seems to be that way :/.
Old Nov 11, 2017 | 02:00 PM
Row2k's Avatar
20 Year Member
G35 Coupe
Originally Posted by LoSt180
I tried looking into the Cadillac CTSV brembos and found that too much material on the spindle has to be removed/ground down in order for a bracket to fit properly. This would be using 350mm G37 rotors.
Didn't know that the 17z and 18z calipers can be bolted up to te G/Z. Who provides the brakcets? Did you look into which one is more appropriate in terms of piston sizing for our platform when paired with brembo or stock rears?
Old Nov 11, 2017 | 11:54 PM
Thumbs up
well thanks for looking that up haha. I'll have to keep an eye out for some akebono's
Old Nov 12, 2017 | 06:31 AM
LoSt180's Avatar
I don't recall off hand, but I think the 17Z had the same piston sizes as the 6-pot CTSV. Also matched up better with Akebono rear calipers.
Brackets, how-to docs, and lots more info are in this Facebook group: https://www.facebook.com/groups/BremboAdaptersByECP/
Old Nov 12, 2017 | 10:12 AM
Row2k's Avatar
20 Year Member
G35 Coupe
Very nice, thank you for the link. I see someone has a 17z kit for sale on there. If you're correct the 18z would match up better with the brembo rears. Either way this is a pretty cool solution for anyone looking to build a budget 6 piston brembo front setup.
Per the ECP site the akebono front rotors are used for both the 17z and 18z with their brackets. Do you know if that's correct?
Old Nov 12, 2017 | 05:40 PM
LoSt180's Avatar
ECP uses G37 sport rotors (akebono) for all of their caliper brackets.
