Z1 subframe collar bushings
Old Aug 21, 2018 | 02:52 PM
  #46
onevq35de's Avatar
I will clean it out a bit though that's not a big concern on mine. Cleaning the face of the bushing on both sides to get good adhesion for the tape to prevent the poly from leaking while curing and how I apply it is a concern and I'll do it as I wrote above. It'll basically be a crude injection mold that never needs to be removed from the mold cause the mold is the housing. As you wrote previously, I'll have to compress the suspension as if it were sitting on the ground. This looks like an easy, cheap, time saving and very effective way to deal with this silly bushing and I have a good feeling about it.
If it works, I'll take the cred and if it's a f'n failure, you get the blame
Old Aug 21, 2018 | 04:39 PM
  #47
Urbanengineer's Avatar
That's great lol. I'd recommend filling a squeeze tube with the stuff and then inject it that way. Your fluid pump likely requires a heck of a lot more fluid to pump.
Old Aug 21, 2018 | 05:56 PM
  #48
onevq35de's Avatar
It should do the trick. Can't think of an easier way though I'll have to kiss this little **** goodbye.
Old Aug 22, 2018 | 05:47 PM
  #49
Unless this stuff flows like water I think it'll instakill your pump. Best of luck.
Old Aug 23, 2018 | 12:59 PM
  #50
cswlightning's Avatar
Only one way to find out! Pretty sure it has a fairly low viscosity so I personally don't see an issue.
Old Aug 23, 2018 | 03:41 PM
  #51
onevq35de's Avatar
I agree. If you watch the vid I posted above, it's pretty f'n runny. This pump moved gear oil without issue which has a very similar consistency..
Picked this stuff up yesterday. I should get around to it Tuesday-Wednesday.
Old Aug 23, 2018 | 04:12 PM
  #52
Sweet!!!
Old Aug 29, 2018 | 06:14 AM
  #53
onevq35de's Avatar
Update on the urethane bushing. Nothing to update. Not gonna happen till next week.
Old Aug 29, 2018 | 07:30 AM
  #54
Sounds good.
Old Aug 30, 2018 | 02:13 AM
  #55
Well my charging system went out so once again subframe bushings are the least of my problems.
Old Aug 30, 2018 | 09:43 AM
  #56
Boy get to work! Waiting on you and CWS and he's got an excuse because of a failing charging system .
Old Aug 30, 2018 | 09:50 AM
  #57
onevq35de's Avatar
Ha! I've got a project that's taking a little longer than I thought.
Old Aug 30, 2018 | 10:01 AM
  #58
Yeah yeah yeah... I won't do this mod to my G till spring anyways if I do. I'm enjoying the tune too much for now and want to enjoy that for a minute!
Old Sep 4, 2018 | 01:50 PM
  #59
onevq35de's Avatar
It's not completed. Got to wait until tomorrow for the urethane to cure. Check out the last post on my thread linked below.
https://www.infinitiscene.com/thread...230572/page-16
Old Sep 4, 2018 | 11:28 PM
  #60
It sure ain't pretty but maybe it worked! You'll have to take video of the diff now at speed. Glad to see it flows like lava though... should be a great option for the rear subframe.
