Slip/VDC OFF, then RAS. After Suspension Install
Old Jun 12, 2019 | 09:14 PM
G35stephen's Avatar
2006 G35 Coupe
Just did a suspension refresh and now I'm throwing Slip/VDC OFF once i hit 25-30 MPH, then RAS joins them after a minute or two of driving. Light all turn off when car is turned off and restarted, then after the 25-30MPH and few min of driving, all lights back on.
Just replaced
- Wheel Bearings
- Control Arms
- Ball Joints
- Tie Rod ends
- Swap Bar End-links
- Sway Bar Bushings
Did not disconnect battery, may have stressed the sensor that bolts to the hub as the knuckle fell forward and was caught by the sensor and the ball joint. Any thoughts are appreciated!
Thank you!
Last edited by G35stephen; Jun 12, 2019 at 10:23 PM. Reason: Adding Wheel bearings
Old Jun 12, 2019 | 09:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Double check that all those wheel sensors got plugged in properly, unplug them all and check for bent pins and such.
Old Jun 12, 2019 | 09:34 PM
G35stephen's Avatar
I'll check the one that's looking at the wheel bearing, that's the only one I messed with?
Kimochi543
Northern California
Jul 7, 2008 11:24 PM
netcbc
Canada
19
Dec 3, 2007 06:10 PM
