Brembo pads/rotors installation questions
Old Dec 10, 2019 | 10:32 PM
nzedwards's Avatar
Bought stoptech pads and r1 slotted rotors for brembo calipers. Stoptech pads came with new hardware (pins, shim, clip).
Should i use the new hardware stoptech provided or re-use my old ones? As i have read a good bit of ppl say re-use old ones from old posts.
And am i suppose to put some type of lubrication/spray anywhere during this install? I do not want constant squeaking brakes
Old Dec 17, 2019 | 01:49 PM
Urbanengineer's Avatar
Specifically you want a little lubrication where the pad contacts the calipers... if it's dry on the shim it may shake and vibrate.
You could reuse, but if new ones fit I'd switch.
Ray Ray
Brakes
14
Oct 6, 2014 03:06 AM
Teyko_XL
Oct 6, 2008 02:00 PM
deanfootlong
Mar 26, 2008 11:01 AM
neffster
Jan 14, 2005 02:19 PM
