cruise control stopped working and my brake pedal appears to be unique
Old Jul 24, 2021 | 04:57 PM
ninjabong's Avatar
So I have the problem with the cruise control not engaging on my 2005 g35 sedan. I get the flashing set light. I have bought a new cruise control cancel switch and installed it and adjusted to specs listen in the manual I've got my cruise to work occasionally but then it will cancel itself and start flashing the set light.
So these rubber stoppers here: are used to push the switches on the brake switch and cruise control cancel switch
https://www.z1motorsports.com/brake-...IaAtPrEALw_wcB
and if you look at brake pedal assemblies for automatic g35's here on ebay you can see there is a rubber stopper for each switch on the brake pedal
https://www.ebay.com/itm/29359555891...Cclp%3A2047675
The issue I have is that my brake pedal assembly only has one hole for a rubber stopper and it's not aligned with either switch. it's actually in the dead center of both switches if I put a rubber circular stopper in there like the ones sold at z1motorsports. it wouldn't touch either switch.
Do I really need a rubber stopper to hit my brake switches? Does anyone know if my car had a different type of rubber stopper? I haven't been able to find any brake assemblies for sale on ebay that resemble mine.
Old Jul 24, 2021 | 05:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like the bracket is bent and not making contact where it should on the pedal stop.
Take a picture of your pedal switches so we can see it.
Old Jul 24, 2021 | 07:46 PM
ninjabong's Avatar
you can see it right here it's not bent. very hard to get a good picture in that tight area I can take a better one if you aren't convinced it's not bent
G35 Tyler
Aug 15, 2020 06:17 PM
Mosesg35
Feb 14, 2020 08:00 PM
Jalford1
V36 DIY
Jan 25, 2019 09:19 PM
AlaskanG
Jan 29, 2016 04:37 PM
Infinitz
Florida G Club
May 19, 2005 09:11 PM
