ABS sensor
Old Apr 21, 2022 | 03:32 AM
QX1's Avatar
QX1
ABS sensor
Does anybody knows in G35 sedan V35 6mt rwd, does the factory requires of using wheelbearings only OEM, or you can use Timken, SKF etc brands also. does anybody had issue with not compatible with ABS speed sensor ? when you get faulty code C0311 that refers the problem with abs speed sensor, do you have to use oem sensor or also aftermarket?
Old Apr 21, 2022 | 08:03 AM
QX1's Avatar
QX1
Originally Posted by QX1
Does anybody knows in G35 sedan V35 6mt rwd, does the factory requires of using wheelbearings only OEM, or you can use Timken, SKF etc brands also. does anybody had issue with not compatible with ABS speed sensor ? when you get faulty code C1103 that refers the problem with abs speed sensor, do you have to use oem sensor or also aftermarket?
the code is c1103
Old Apr 29, 2022 | 04:49 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
I have a Timken bearing/hub assembly on my coupe. No issues.
Old Nov 29, 2023 | 07:50 PM
maxsg351's Avatar
gray Coupe - nothing extra special
Hi QX1. I have the same question for my rear bearings on 2005 G35. What did you wind up doing?
Thanks
Matt
iGoMeep
Feb 20, 2022 09:39 PM
betta-j
Aug 4, 2020 11:09 AM
Gorhad
Apr 7, 2015 11:15 AM
logicalloco
Jun 19, 2011 09:15 PM
