When to change the rotors?
Old Jul 11, 2005 | 01:21 PM
Buddha's Avatar
I currently have 28000 miles on my car and my brakes are wearing out. Currently on my rotors, there is a little ridge on the outer part of the rotor. Should I just replace the rotor or resurface it?
Old Jul 11, 2005 | 01:52 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
FWIW,
At about 30K it's pretty safe to say you should replace the rotors.
After a little wear there's not much left to turn down.
Standard thickness = 24.0 mm
wear limit = 22.0 mm
& also depends on run out; max = .035mm
Old Jul 11, 2005 | 01:56 PM
Infinite1's Avatar
20 Year Member
Wow buddha you're better than me....the dealer just resurfaced my rotors and i have only 12K on them...heheehh...
Old Jul 12, 2005 | 08:19 AM
Q45tech's Avatar
You people have it so very easy..........for the last 15 years I have resurfaced my rotors every 6-9,000 miles doing a fine 0.003" touch up each time.......still get around 40,000 miles per rotor set..........the 7th set of new rotors is now due [290,000 miles 90 Q45]. Since I discovered brakealign rotor shims I'm able to reset the rotor surface to 0.001" or better each time which now gives me the 9,000 miles between retrueing.
I'm super sensitive to any vibration.
Old Jul 12, 2005 | 08:44 AM
InTgr8r's Avatar
Q45tech,....Thanks for the info.
Here's an interesting read on the product,
LINKY
Old Dec 28, 2005 | 01:27 PM
PEPPY's Avatar
Had my rotors cut for the first time at 62,000 mi. Took them off myself, & had Pep Boys recut all 4 for $36.00 total. Replaced pads $38.00 an axle, got full brake job for under $120.00 Went to Pro Cermac pads, work great.
Old Dec 29, 2005 | 02:20 AM
EricIsKlumzyee's Avatar
use a mic and measure it urself!!
Old Dec 29, 2005 | 09:15 AM
RBull's Avatar
Rated M
Interesting info from both Qtech and Intgr8r.
Thanks
Jiggerjuice
Aug 26, 2015 09:00 AM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
