Pads & Rotors
Old Oct 8, 2005 | 01:01 PM
jbroadbent001's Avatar
Pads & Rotors
I need to replace my pads and rotors on the front. I would like to do this myself instead of being gouged by the dealer. Where do I order the replacement parts and what additional parts and tools will I need to get the job done?
Thanks.
Old Oct 8, 2005 | 01:05 PM
D87's Avatar
D87
If the car is under 3 years and 36000 miles and not a '05 or '06, the pads and rotors are warrantied by Infiniti because of a law suit. They'll change both free under this clause (I've had this done at the dealer already). Good luck!
Old Oct 8, 2005 | 01:08 PM
I wish I was in that category D87, unfortunately I have a 2003 with 59K miles. Infiniti reimbursed me for pads and rotors the 1st time around. This is the second time I get to replace the rotors.
Old Oct 8, 2005 | 03:29 PM
ABQ_G35's Avatar
That added warranty came out before the lawsuit was filed, besides, I don't think that lawsuit has been settled. I got the letter right after buying my '04 in October of '03, it seems like it came in November.
Old Oct 9, 2005 | 10:27 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
God....get rid of 'em and install the 'Metal Matrix' pads from Stillen. Work GREAT, not expensive ($100 +/- a set), and NO dust!.....I replaced mine (OEM) on my 04' before I had a hundred miles on 'em.... so I didn't even bother turning the rotors. Did so because I knew what I was in for (worked for Infiniti) and couldn't be bothered with all the warranty crap. Took me an hour to install in my driveway. Great 'bang for the buck'......but, I'll be go'in after-market rotors (drilled and slotted), pads, and stainless lines this spring. Check out the various (and plentiful) older posts via the 'search' concerning the 'Metal Matrix' and other brands of after-market pads. B.Cool JBX
Old Oct 9, 2005 | 10:50 AM
JBX, so should I get OEM rotors and replace the pads with stillen metal matrix pads?
Old Oct 9, 2005 | 04:01 PM
Yeah sure........the pads are/always have been the weak link in the brake chain. Simple install. I knew that I would swap them out long before I had even taken the delivery of my X. B.Cool jbx
Old Oct 10, 2005 | 03:52 PM
LuXXXz's Avatar
JBX
i want to get some brake pads too, so you're saying i should leave the stock rotors and just replace the pads???
i have an 03 w/ the brake issues also, but the brake issuse was the pads only ,the rotors were fine right???
Old Oct 10, 2005 | 04:01 PM
shodog's Avatar
Rotors and pads are available from kragen and poop boys. Expect to pay about $175 for the three of them.
Old Oct 10, 2005 | 05:36 PM
saborz's Avatar
My 03.5 sedan has 18,000 miles on it and is coming up on the 3-year mark. I have not had any issues with my brakes, but I do now feel a ridge around the edge of the rotor that my dealer previously said was an indicator of rotor wear. Anybody have any luck getting the dealer to replace the rotors and pads under warranty, even if there is no readily apparent problem with the breaks? Or will they take a measurment and if it's not at or below the minimum thickness, just tell me "too bad, yours aren't worn enough?"
Old Oct 10, 2005 | 06:32 PM
ChicagoX's Avatar
Don't drink and Mag Race
I believe that the minimum service thickness is 2mm for the pads. Unless you are complaining of a noise or performance issue, I doubt they will change the setup.
It doesn't hurt to ask; call your service advisor to set up an oil change and to check out the "grinding" you hear when the brakes are cold.
Old Oct 11, 2005 | 09:14 AM
Originally Posted by LuXXXz
JBX
In theory yeah.........If your rotors have taken too much of a beat'n from the OEM pads, your warranty should cover the replacement of the front and the 'turning' of the rear. Just replace the stock with the after-market on fresh/new rotors. I just slapped mine on because there was less than a hundred miles on the car. You should always give new pads a fresh surface BCool,jbx Pictures below were taken this rainy morning (click-on to enlarge).....Pads have 8,500 mile on em' and wheels have gone over two week without a bath!..lol The Metal Matrix wear clean and do a great job (once their warmed up of course) jbx
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
