Help with alignment specs - help Kenchan! :)
Old Oct 27, 2005 | 10:28 AM
Burrcold's Avatar
Kenchan:
I have the OEM 19's, however, I am switching over to a 17 inch winter rim that are 17/55 rear and 17/50 front. Do I need to change my alignment when switching over to the smaller rim size? Oh and I am on the Eibach prokit as well.
If you can (because I trust your number to bring into my alignment guy hehe) could you put what you think is the optimal settings, within OEM spec, that would acheive a balance between performance and minimal premature tire wear. By the way I do alot of highway driving if that matters. Sorry for the noob questions.
Front
Camber
Caster
Total Toe In
Rear
Camber
Total Toe In
Thank you for all your advice in advance!
Old Oct 27, 2005 | 02:11 PM
kenchan's Avatar
You don't need to get an alignment just for swapping wheels, but if you haven't gotten an alignment after the prokit install here's some numbers you might want to hand over to the tech:
FRONT
camber: non adjustable (you'll see -1.9 to -2.2 range on Prokits)
caster : non adjustable (you'll see 8+ range)
Total toe: tell tech to set at 0.10
REAR (if you have camber rods)
camber: tell the tech to target -1.2
total toe: tell the tech to target 0.32
REAR (if you don't have camber rods)
camber: tell the tech to target most positive allowed
and match other side.
Unless you sit in the car while the car is adjusted, the car will sit about 0.3" higher than its usual height while the tech works on adjustments. Getting alignment done on these lowering springs is pretty tricky as you need
to compensate how much lower the car would sit after it re-settles.
If you have H-techs/S-techs its even worse... car would sit like 1" higher
while the tech works on your car unless your springs are completely settled.
this results in toe-out and massive negative camber conditions on the rear
after your car re-settles.
been there, done that, fixed it and learned...
Old Oct 27, 2005 | 03:16 PM
Burrcold's Avatar
FRONT
my apologies Kenchan, I should have mentioned that I have the Kinetix front kit and SPC rear kit...also the springs have been on for 6 months now. What would be my optimal settings given this new information?
Again sorry for the hassle.
Old Oct 27, 2005 | 04:21 PM
kenchan's Avatar
oh, in that case if you want a factory-like ride, then have them set it to the factory specs.
if you want to play around with the setting, take it to factory specs, drive around with it for a while and then fine tune (dial-in) the alignment to your
preference. ie, you want more turnability, increase front camber, lessen rear camber. or vise versa. increase straightline stability, increase toe-in ,etc.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
