Rub/clank noise after Tein S-Tech springs.
Old Oct 27, 2005 | 10:36 PM
Timskyline350gt's Avatar
Hi all,
I have a 03 coupe. After installing Tein S-Techs springs, I am hearing some kind of rub/grind noise when I turn the steering wheel a lot. I do have 19x8.5 rims w/ 245/35/19 tires in front. I know its not the wheels cause I checked the clearance. The sound happens mostly when I am going up a drive way while turning the wheel, or sudden accelerations/decelerations while turning the wheel.
The noise is very short, and it doesn't drag on. Its kinda like clank.....clank...clankclank...
What could it be?
Old Oct 29, 2005 | 01:05 AM
shoeboy3004's Avatar
could be the front sway bar being loose because the front wheels have to be loaded with weight to be correct. i had the same problem and went about and had the swaybar retightened top and bottom on the end links and it went away.
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
