Spring install nightmare
Old Oct 28, 2005 | 11:59 PM
waijai's Avatar
i.love.gold
So yeah I ended up installing 3 out of 4 springs. On my 4th spring everything was going fine...positioned the spring/shock back into place and bolted it back to the lower control arm. As I'm going to re-connect the sway bar end link rod, I see the bolt has been damaged. It was from when i tried to pound it out of the hole, the threads got damaged. I tried to use a tap/die set to rethread the bolt, but it's been damaged to badly.
Does anyone know if I can buy one of these at the dealership parts department?
Old Oct 29, 2005 | 12:36 AM
SleekStyle's Avatar
yes you can
damn dude, a hammer is not always the solution
good louck man
Old Oct 29, 2005 | 01:01 AM
waijai's Avatar
i.love.gold
lol I know that now...I should have just jacked up the lower control arm and it woulda popped right out.
I have the part # I just looked up...hopefully they have it in stock. Same part # at Nissan is $13 and at Infiniti its $18.
Old Oct 29, 2005 | 10:02 AM
kenchan's Avatar
front endlink.
the way to remove those is to raise the control arm to about the same height on both L/R and there should be very little to no tension where you
can just pull/push out by hand.
Old Oct 29, 2005 | 11:38 AM
my_Gthang's Avatar
did you get your part yet?
Old Oct 29, 2005 | 12:38 PM
waijai's Avatar
i.love.gold
Yeah fortunately the dealer had one in stock. Everything is back together this morning.
Yeah kenchan, I don't know why I started pounding on it, when the passenger side just popped out. Lesson learned.
Old Oct 29, 2005 | 12:49 PM
my_Gthang's Avatar
then where are the pics????
kenchan's Avatar
cool, let us hear how your car is with the new springs.
Old Oct 29, 2005 | 12:59 PM
vodkarocket's Avatar
Modded Member
^Better yet, let us see how it sits with the new springs!
Old Oct 29, 2005 | 01:12 PM
waijai's Avatar
i.love.gold
I'll take some pics later today after I wash the car.
Old Oct 30, 2005 | 01:18 AM
VinNYCG's Avatar
G SQUAD
What kind of springs??
-Vin
Old Oct 30, 2005 | 01:28 AM
cmayer's Avatar
sway arm bolt
another quick tip is to get both front wheels off the ground. then it will come right out. if you do not lift the other side off the ground it will have a ton of tension on it.
snic09
Nov 8, 2017 01:46 PM
EPG35
Aug 16, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
