Alignment & Camber Specs
Old Jul 25, 2003 | 06:18 PM
Rumble's Avatar
Does anyone know the factory alignment and camber specs? I lowered my car and need the specs to get my car aligned. I have a G35 sedan. Can someone also confirm for me that the rear of my sedan is able to adjust camber WITHOUT a camber kit? It comes stock with camber adjustability correct? Thanks in advance.
It's still a G thang!!
Old Jul 26, 2003 | 12:11 PM
Rumble's Avatar
Re: Alignment & Camber Specs
Please help...I need this done before Wednesday.
Old Jul 26, 2003 | 01:28 PM
Gsedan35's Avatar
I only have the specs for the 350Z from the service manuel, which is just as well since I'm running 350Z springs and struts. I'd post that info, but I don't think you'd want it. (I did try of the heck of it, but in converting the PDF file to a JPG file, it was unledgeable. And cut and paste in text mode did work either, all messed up.)
I'll bet if you went to the dealer, they'd be willing to hand you a photo copy of the specs from the service manuel, just a thought.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
350Z springs&struts
Old Jul 26, 2003 | 01:29 PM
Gordgee's Avatar
Administrator
Try this:
SERVICE DATA PFP:00030
Wheel Alignment (Unladen) AES00009
Ball Joint AES0000A
Wheelarch Height (Unladen*) AES0000B
*: Fuel, radiator coolant and engine oil full. Spare tire, hand tools and mats in designated positions.
Camber
Degree minute (Decimal degree)
Minimum - 0°50′(- 0.83°)
Nominal - 0°05′(- 0.08°)
Maximum 0°40′(0.67°)
Left and right difference 45′(0.75°)
Caster
Minimum 7°00′(7.00°)
Nominal 7°45′(7.75°)
Maximum 8°30′(8.50°)
Kingpin offset
Minimum 3°45′(3.75°)
Nominal 4°30′(4.50°)
Maximum 5°15′(5.25°)
Total toe-in
Distance (A - B)
Minimum 0 mm (0 in)
Nominal 1 mm (0.04 in)
Maximum 2 mm (0.08 in)
Wheel turning angel Refer to PS-8, "FRONT WHEEL TURNING ANGLE"
Oscillating torque
Less than 2.0 N•m (0.20 kg-m, 18 in-lb) (Upper link)
0.147 - 2.45 N•m (0.02 - 0.24 kg-m, 2 - 21 in-lb) (Compression rod)
Measurement on spring balance (cotter pinhole position)
Less than 34.8 N (3.5 kg, 7.8 lb) (Upper link)
2.37 - 39.5 N (0.24 - 4.03 kg, 0.53 - 8.88 lb) (Compression rod)
Sliding torque
0.147 - 2.45 N•m (0.02 - 0.24 kg-m, 2- 21 in-lb) (Compression rod)
Axial end play 0 mm (0 in)
Applied model 205/65R16 215/55R17
Front (Hf) 711 mm (27.99 in) 711 mm (27.99 in)
Rear (Hr) 703 mm (27.68 in) 704 mm (27.72 in)
SFA818A
FSU-16
SERVICE DATA
<font color=green>GG</font color=green>
Old Jul 26, 2003 | 03:14 PM
Rumble's Avatar
Thanks guys, I'll be doing it on Monday or Tuesday.
Old Jul 26, 2003 | 05:39 PM
Gsedan35's Avatar
Is that a camber spec for front and rear? Or just the front? Doesn't the rear call for some negitive camber?
Ivry 6mt sed
Kumho MX 245/40
350Z springs&struts
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
